  • Replies 62.7k
  • chaos
    7164
  • Ska
    5791
  • BelGarion
    3645
  • Nexus9
    3590
personally the funniest home vids chick annoys me
i like the nine goldcoast weather woman
ud know her also as lady luck from the footy show
yeh she's so lame and corny...
but for some reason I keep watching the show...
i keep seeing :boobs:
perhaps negotiate with someone who has one going cheap over some postage? best to try ringin round, rma are usually pretty good, i tried everywhere and them last, and they were the only ones i could find with a q45 afm, for a good price too (better than id been offered) AND it was brand new too
1. 9 BUTTON BAR Honda M 1'28"827 208.639 Km/h 13
2. 1 M.SCHUMACHER Ferrari B 1'29"064 + 0'00"237 15
3. 10 SATO BAR Honda M 1'29"127 + 0'00"300 15
4. 6 RAIKKONEN McLaren Mercedes M 1'29"354 + 0'00"527 12
5. 2 BARRICHELLO Ferrari B 1'29"545 + 0'00"718 13
6. 8 ALONSO Renault M 1'29"555 + 0'00"728 13
7. 5 COULTHARD McLaren Mercedes M 1'29"955 + 0'01"128 14
8. 4 R.SCHUMACHER Williams BMW M 1'30"176 + 0'01"349 9
9. 17 PANIS Toyota M 1'30"277 + 0'01"450 14
10. 16 DA MATTA Toyota M 1'30"316 + 0'01"489 16
Guest
    • Pretty much what you'd expect at that power level. Hypergear turbo, long list of supporting mods, full Haltech catalogue, etc.  I'd say this goes for most drivers, suspension is still a dark art for most people. And it's really hard to convince someone how much better their setup could be...
    • They are what I will be installing. 640s for me.
    • Hmm... From my experience you get about 0.25° camber change per mm of RUCA length change. So, to correct from -2.5 up to less than -1° (or, more than -1° if you look at the world as a mathematician does) then you'd be making 6-8mm of length change on the RUCA. From a stock length of 308mm, that's 2-2.5% difference in RUCA length. My RUCAs are currently very close to stock length - certainly only 2-3mm different from stock. I had to adjust my tension arms by 6mm to minimise the bump steer. That's 6mm out of 210, which is 2.8%. That's a 2.8% change on those, compared to a <1% change on the RUCAs. So the stock geometry already has worse bump steer than is possible - you can improve it even if you don't change the RUCA length. If you lengthen the RUCAs at all, then you will definitely be adding bump steer. Again, with my car, I recently had an unpleasant amount of bump steer, stemming from a number of things that happened one after another without me having an opportunity to correct for them. I only had to change the tension arm lengths by 1mm to minimise the resulting bump steer. (Granted, I also had to dial out a lot of extra toe-in in the rear, and excessive rear toe-in will make bump steer behaviour worse). Relatively tiny little adjustments having been made - the car is now completely different. Was horrifying how much it wanted to steer from the rear on any significant single wheel bump/dip. And it was even bad on expansion joints on long sweepers on freeway entry/exits, which are notionally hitting both rear wheels at the same time. My point is, the crappy Nissan multilink is quite sensitive to these things (unlike the very nice Toyota suspension!). And I think 99.75% of Skyline owners are blissfully ignorant of what they are driving around on. Sadly, it is a non-trivial exercise to set up to measure and correct bump steer. I am happy to show my rig, which involves nasty chunks of wood bolted to the hub, mirrors, lasers, graph paper targets and other horrors. Just in case anyone wants to see how it is done. I'll just have to set it up to take the photos.
    • What do you have in that bad boy ? Ill go with the 725cc since I'll be going with Nistune ( would definitely like more engine protection but Haltech is too far out of reach at the moment... plus, Ill probably have a pretty safe tune as its a daily, not gonna be chasing peak power 24/7 ahahah ). Are Xspurt a safe choice?  Pete's great. He didnt mention anything about traction arm length so I reckon it may be good. When I get some new wheels/tire later down the road I'll ask him about it and get his opinion on em. I heard from Gary that you've got the bilsteins too, are you running the sway bars too? and what other suspension goodies do you have installed or would recommend?
    • In true Gregging style...
