  • Replies 62.7k
  • chaos
    7164
  • Ska
    5791
  • BelGarion
    3645
  • Nexus9
    3590
Just came home, ive never spanked so many holdens and ford in one day!!! NEW QTR TIME TOO, unforunately i got this time 2nd last round of street bracket racing on a 13.5 dial in so i was both happy and very pissed off at the same time, none the less i had a ball.
Guest
