go front strut bar and sway bars.... front and back.... even with stand springs and shocks, you will still easily out manevour most cars....
you trying to get me broke?! :)
you keep giving me ideas to add more mods to the car, probably end up doing a RB25DET engine transplant and a T88 and nos.... :headspin:
  • Replies 62.7k
  • chaos
    7164
  • Ska
    5791
  • BelGarion
    3645
  • Nexus9
    3590
yeh but dont forget exhaust...will be lower than your standard one
not really benny boy... max piping size for NA should only be 2.25 inch catback and muffler size is almost same as stock....
you go anything more than 2.25, you will lose back pressure.... less torqy....
ME giving you ideas?? :confused:
i would go handling first..... no point spending thousands to squeeze a few more KWs outa the car...
awesome handling makes you a better driver...
I've got a twin cannister 3.5" exhaust sitting in the garage :)
ya, I'm going for tyres first Glenn costing me a butt load too.... almost half my uni tuition.
can sometimes even be just be the gaskets or rubber mountings.. gaskets are like $2.50 to replace
where can i get this checked out? at a normal garage???
yup.. not cheap..
krawler: no.. they're just spring and shock setup.. i sold my old set for $200, they were sitting around for ages
Doesnt coil over simply mean the coil is over the shock?
Meaning that most cars are coil over factory.. The term coil over is normally targetting adjustable gear though.
i know... It was on the NA, but got it taken off for compliancing.. and power loss.
now i'm stuck with a stupid rattle.
get 2 jacks and a creepboard.... rip out the heat shield....
if not the heat shield... hammer the resonator gently to check for rattling...
i think the difference is.. with coilovers, the shock is actually welded to the bottom of the spring, and they are basically one unit and cannot be separated. Most things can be adjustable.
With a spring and shock setup the springs and shocks can be separated and changed independently. In that setup you can adjust the shock, but not the actually spring height or anything like that.
Guest
    • Pretty much what you'd expect at that power level. Hypergear turbo, long list of supporting mods, full Haltech catalogue, etc.  I'd say this goes for most drivers, suspension is still a dark art for most people. And it's really hard to convince someone how much better their setup could be...
    • They are what I will be installing. 640s for me.
    • Hmm... From my experience you get about 0.25° camber change per mm of RUCA length change. So, to correct from -2.5 up to less than -1° (or, more than -1° if you look at the world as a mathematician does) then you'd be making 6-8mm of length change on the RUCA. From a stock length of 308mm, that's 2-2.5% difference in RUCA length. My RUCAs are currently very close to stock length - certainly only 2-3mm different from stock. I had to adjust my tension arms by 6mm to minimise the bump steer. That's 6mm out of 210, which is 2.8%. That's a 2.8% change on those, compared to a <1% change on the RUCAs. So the stock geometry already has worse bump steer than is possible - you can improve it even if you don't change the RUCA length. If you lengthen the RUCAs at all, then you will definitely be adding bump steer. Again, with my car, I recently had an unpleasant amount of bump steer, stemming from a number of things that happened one after another without me having an opportunity to correct for them. I only had to change the tension arm lengths by 1mm to minimise the resulting bump steer. (Granted, I also had to dial out a lot of extra toe-in in the rear, and excessive rear toe-in will make bump steer behaviour worse). Relatively tiny little adjustments having been made - the car is now completely different. Was horrifying how much it wanted to steer from the rear on any significant single wheel bump/dip. And it was even bad on expansion joints on long sweepers on freeway entry/exits, which are notionally hitting both rear wheels at the same time. My point is, the crappy Nissan multilink is quite sensitive to these things (unlike the very nice Toyota suspension!). And I think 99.75% of Skyline owners are blissfully ignorant of what they are driving around on. Sadly, it is a non-trivial exercise to set up to measure and correct bump steer. I am happy to show my rig, which involves nasty chunks of wood bolted to the hub, mirrors, lasers, graph paper targets and other horrors. Just in case anyone wants to see how it is done. I'll just have to set it up to take the photos.
    • What do you have in that bad boy ? Ill go with the 725cc since I'll be going with Nistune ( would definitely like more engine protection but Haltech is too far out of reach at the moment... plus, Ill probably have a pretty safe tune as its a daily, not gonna be chasing peak power 24/7 ahahah ). Are Xspurt a safe choice?  Pete's great. He didnt mention anything about traction arm length so I reckon it may be good. When I get some new wheels/tire later down the road I'll ask him about it and get his opinion on em. I heard from Gary that you've got the bilsteins too, are you running the sway bars too? and what other suspension goodies do you have installed or would recommend?
    • In true Gregging style...
