  • Replies 62.7k
  • chaos
    7164
  • Ska
    5791
  • BelGarion
    3645
  • Nexus9
    3590
and i got hassled by a wrecks on the way home. he was a complete ****wit. accelarating to 150+ up beside me and nearly smashed up the arse of the car infront of him. he had to pull infront of me. his brakes werent as good as he thought. wanker....
Guest
