well long story with that....2 years ago they were a bit hard to find...so I basically hassled the shit out of anyone remotely skyline related :)
The search turned my one at Autoterminal at meadowbrook...it had been in the country for 5 days...so I bought it then and there :)
  • Replies 62.7k
  • chaos
    7164
  • Ska
    5791
  • BelGarion
    3645
  • Nexus9
    3590
Guest
