  • Replies 62.7k
  • chaos
    7164
  • Ska
    5791
  • BelGarion
    3645
  • Nexus9
    3590
Wait, I remember you now. You were the guy who was downloading porn on his mobile phone on GPRS last night to get a lesbian background for someone elses phone while the Ghostbusters theme song was playing on the video jukebox in the pool hall. was that you?????
Guest
