We were going to do the fmic ourselves as well to save some money, but we ran out of time with the car being booked into gav's for tuning and the cooler only arriving the day we were meant to drop it down. So I just wanted it on and stuff, I did have a choice, but I'm stubbern and wanted the cooler on asap. I've waited 2 damn years for the thing!!
  • Replies 62.7k
  • chaos
    7164
  • Ska
    5791
  • BelGarion
    3645
  • Nexus9
    3590
They only left the numberplate bar in because I said I was going to get the car resprayed and the panel beater would do it. But, I don't know if that is going to happen now. Plus I don't want the cooler there for poser value. It's actually doing something. Not just sticking out the front of the car screaming "HI, I'M A FMIC, PLEASE COME STEAL ME!"
I kinda like the hidden look, and it's kinda protecting it against rocks and the like. But, I know it's "KINDA" restricting flow. Not that much, but anything's a help.
hey
i was just reading your posts and wondering whats the best way to cut your bar cause i have a cooler arriving sometime this week and i want to cut the bar a little but not to much, cause i agree with what you said erin i dont want to be a posser but i do like a little show(but not to much)
i hope ive got the time to put it in too. i think im going to finish at lunch time on a friday and hit it hard friday arvo/nite. then i can get what i need on saturday and finish off on sunday. i did watch my next door neighbour put one in his 32 and it took him 4 hours from start to finish.
With a HKS cooler it should be easy like mine. Because they are actually made specifically for that type of car by a company that's reputable (is that the word?) by nissan.
I was worried it would take ages, but the only thing they had to do was cut a hole in the front drivers side to let the pipe through (that's if you aren't using the standing piping).
Wade, I'm really not sure about 32's, but in the R33's they've got a support bar behind the plastic numberplate holder which has to be cut (which is another reason mine wasn't cut out). Because I got a thicker than normal cooler (apexi coolers are thicker but not as tall) 88mm thick, they had to cut a bit of the lower lip away to fit the cooler properly. But that is the ONLY thing that was cut. Perfect fit otherwise.
Not like the hybrid kits for R33's where I've been told that the first instruction is to cut your fan blades so the pipes fit properly without hitting the pipe..
wade - do you have a gtst or gtr? my neighbour got a greddy kit i think and he didnt cut anything at all, but it was one of those kits where the pipe bends back under the cooler and fits upto the stock turbo piping. i'll be using a 70mm holesaw to drill the chassis rail.
Guest
