  • Replies 62.7k
  • chaos
    7164
  • Ska
    5791
  • BelGarion
    3645
  • Nexus9
    3590
This must be the year for cancer ;) My sisters mother in law died in February this year to cancer. She had lots of it. In her spine, chest. It was terrible just waiting for her to let go. She also had pneumonia which made things worse.
Plus at the moment, my grandfather has throat cancer.
All the more reason to donate to cancer research. Donate to the cure, not the cause.
Guest
