  • Replies 62.7k
  • chaos
    7164
  • Ska
    5791
  • BelGarion
    3645
  • Nexus9
    3590
Yeah mine was fine, but the next day it was no go. Pulled it all out and realised the pickup had come off, probably due to using the wrong hosing which had warped after being in fuel for a night.
Then was told it was wrong pump, then told it was ok.
So the orginal is in and I need to install the Bosch again *big sigh*!
shane what went wrong?
i did mine and it seemed to go fine
nah shane, the stock pickup reaches into the tank heaps more than the 040
the 040 is built into the pump so the pump has to be mounted further down the pickup
i havent run it down too far but i pushed it down to the empty bar and it was still running so i think its not too bad
probably the best method is too actually soak the rubber in petrol overnight so that it expands before you put it in..
my pickup fell off.. drove it around the block few times.. opened it up again.. saw it had come off.. put it back on.. drove around block.. opened up again next day just to check .. seems to have been ok since.
yeah... it was a bit difficult to find the spot.. but i checked the stock spot a few times just to see where it sat stock.. then made sure the aftermarket one went in exact same spot.
james: do you have a bill from your work yet?
Guest
