  • Replies 62.7k
  • chaos
    7164
  • Ska
    5791
  • BelGarion
    3645
  • Nexus9
    3590
yeh...hit the corner at like 80-100 but cant be sure as i was a little too preoccupied with everything else.... needless to say it left big black marks and impressive smoke
and some brown stains....
big mthrfker smok'n
ah ok that tyre is not happy
f**k owned I think u r a luck boy not to of done any damage to your car or your self
becare full man hey don't want to see you get hurt :Oops:
it is interesting to see what your car can do with some one who knows the fine art of driving
being on the skid pan & watching the guys driving there own cars & then watching the instructors drive it is not funny but even they were getting it wrong :flamed:
ey shane, you have another go at the fuel pump?
Will soon mate, bought some more hosing and other bits today.
Been trying to source a new pickup, but Nissan won't sell me the pickup by itself, they said I have to buy the whole assembly - $700+. I dont think so!
Me thinks I might have to just use a long hose to the bottom of the tank with a stocking on the end as a filter?
hey shane who r you trying to get the pickup off (What Dealer Ship?)
Guest
    • What can't be done with a little bit of decking board or similar timber bolted to a hub flange via 2 wheel nuts is not worth talking about.
    • I noticed something. On the tps sensor and the sensor behind the adjustment screw is adjusted towards the far left. Are these screws supposed to be centered? (this sensor was in the same position before the tune as well)  Also attached a photo of where my car usually idles at when warm (sometimes a tiny bit above that). I think I might have screwed up the calculation and it might have better than I thought lol at 750rpm still not 650rpm though.
    • So for both general interest of engine health, and to rule out any coolant/oil issues, I organised an oil analysis done on the 125,000klm oil Results below, all good, just a bit of fuel dilution which I'm not too worried about
    • This is actually a really good way of measuring what wheels fit. If only there was a similar measurement between hub face and suspension :p That said, it's probably pretty simple to actually measure it all with the wheel off the car for the rear. The front is a bit more complex but..
    • Being the top Google search result for R34 wheel-related inquiries, lemme throw down my experience. I calculated that 100mm from hub face to wheel face is about the perfect fitment for my ENR34 sedan.  I've been running 18x8.5s, ET35, with a 1" spacer. So, 8.5in to mm = 216mm. 216/2 = 108mm. 108-35 = 73mm. 73+ 25 (1" to mm) = 98mm.  If you wanna get close to this on dif widths, here are the offsets you'll want: 9" - ET around 15mm 9.5" - ET around 20mm 10" - you're crazy, but ET around 30mm All these should fit perfectly on a non-widebody, non-GTR Skyline. Note that it's probably the absolute max, and you're probably better off running a couple degrees of camber in this config, but it looks great, super flush.
