So the race is on again eh? I dont think I can beat the undisputed king of whores, as I just cant do it, I actually have a bit of a life and am not willing to give up that little bit of humanity i ave left in me, but at nearly 400 posts, it's gonna take a lot of whoring, and once you get your car back, i cant see you spendin too much time out of it :(
  • Replies 62.7k
  • chaos
    7164
  • Ska
    5791
  • BelGarion
    3645
  • Nexus9
    3590
cyrus the reason your stock bov venting to the atmo makes your car run like shit is cause it opens on idle slightly, from what ive been told it also has a small hole in it to allow some of the boost pressure to escape for some ungodly reason.
its something to do with emissions control and making the car run smoothly
dont take my words as gospel tho, better off askin someone who knows
points cant be used unless you donate.....
so donate
I have donated, still cant access store :(
Blocked that little hole, it is wierd once it starts to spool about half way to hitting boost the stock bov just starts continually venting, then you have to accelerate hard to get past that and hit boost, then it stops venting until you stopp accelerating
Guest
    • What can't be done with a little bit of decking board or similar timber bolted to a hub flange via 2 wheel nuts is not worth talking about.
    • I noticed something. On the tps sensor and the sensor behind the adjustment screw is adjusted towards the far left. Are these screws supposed to be centered? (this sensor was in the same position before the tune as well)  Also attached a photo of where my car usually idles at when warm (sometimes a tiny bit above that). I think I might have screwed up the calculation and it might have better than I thought lol at 750rpm still not 650rpm though.
    • So for both general interest of engine health, and to rule out any coolant/oil issues, I organised an oil analysis done on the 125,000klm oil Results below, all good, just a bit of fuel dilution which I'm not too worried about
    • This is actually a really good way of measuring what wheels fit. If only there was a similar measurement between hub face and suspension :p That said, it's probably pretty simple to actually measure it all with the wheel off the car for the rear. The front is a bit more complex but..
    • Being the top Google search result for R34 wheel-related inquiries, lemme throw down my experience. I calculated that 100mm from hub face to wheel face is about the perfect fitment for my ENR34 sedan.  I've been running 18x8.5s, ET35, with a 1" spacer. So, 8.5in to mm = 216mm. 216/2 = 108mm. 108-35 = 73mm. 73+ 25 (1" to mm) = 98mm.  If you wanna get close to this on dif widths, here are the offsets you'll want: 9" - ET around 15mm 9.5" - ET around 20mm 10" - you're crazy, but ET around 30mm All these should fit perfectly on a non-widebody, non-GTR Skyline. Note that it's probably the absolute max, and you're probably better off running a couple degrees of camber in this config, but it looks great, super flush.
