  • Replies 62.7k
  • chaos
    7164
  • Ska
    5791
  • BelGarion
    3645
  • Nexus9
    3590
Geeze cmon ppl GET WITH THE PROGRAM!
I am here to pump you up!
Hmmm maybe I really should not make coffe with 20 teaspoons of coffee and 25 teaspoons of sugar, problem is that you can only add half and then you have to dissolve it in the water because it fills up the cup, once you add water you can put in heaps more :D
Then agin rush hour has just started with users complaining nothing works and everything is too slow, so might have to not whore for a while, GOD DAMN USERS, PISS OFF STOP CALLING ME! Fix your own computers! :D
Guess I'd better not post crap, that is just not classy whoring, so nice wether we have today, dont you think, yes that is right I am talking to you, you have been bothered to read through all this whoring crap so might as well see who it is who are dedicated enough to pour through reams of crap for the occasional interesting post :D
Guest
