  • Replies 62.7k
  • chaos
    7164
  • Ska
    5791
  • BelGarion
    3645
  • Nexus9
    3590
http://www.mrcontrols.com/images/badblock1.jpg
http://www.mrcontrols.com/images/badblock2.jpg
http://www.mrcontrols.com/images/badblock3.jpg
A while back we saw a block failure at the ~700rwhp level on Chemvolt's engine. Here is another failure from toymanf's engine. This engine was doing it's first competitive 1/4 mile run.
Toymanf is not sure how much power he was making on the run, but the dyno he was on while getting the engine set up gave 540rwhp on turbo only (all subsequent runs were done with the tires spinning on the dyno) and the 1/4 mile run on which the engine failed was running that plus a 200 shot of nitrous.
The tune was conservative and you can see that there are no signs of detonation on the piston or cylinder walls. EGT temps were fine. AFRs were in the 11s. Fuel was C16.
The block was a seasoned stock block, bored 40 over. A 1.6mm HKS headgasket held down with ARP studs torqued to 65ft/lbs. It appears that the corner of the block around the #1 cylinder was unable to hold the lifting force that the head was putting on it.
There was at least another 100rwhp left untapped in this engine, but it is unclear at this point if the 3s block is capable of holding that much power over the 1/4 mile.
Any thoughts on how to contain +700rwhp power levels and keep the block intact? Sleeves would not have helped here. I've heard of using 1/2" studs but that is going to require a lot of work and I'm not sure if there is enough material in the block to make that work. Would the 5s block more reliably accept this much power and more?
Guest
    • They are what I will be installing. 640s for me.
    • Hmm... From my experience you get about 0.25° camber change per mm of RUCA length change. So, to correct from -2.5 up to less than -1° (or, more than -1° if you look at the world as a mathematician does) then you'd be making 6-8mm of length change on the RUCA. From a stock length of 308mm, that's 2-2.5% difference in RUCA length. My RUCAs are currently very close to stock length - certainly only 2-3mm different from stock. I had to adjust my tension arms by 6mm to minimise the bump steer. That's 6mm out of 210, which is 2.8%. That's a 2.8% change on those, compared to a <1% change on the RUCAs. So the stock geometry already has worse bump steer than is possible - you can improve it even if you don't change the RUCA length. If you lengthen the RUCAs at all, then you will definitely be adding bump steer. Again, with my car, I recently had an unpleasant amount of bump steer, stemming from a number of things that happened one after another without me having an opportunity to correct for them. I only had to change the tension arm lengths by 1mm to minimise the resulting bump steer. (Granted, I also had to dial out a lot of extra toe-in in the rear, and excessive rear toe-in will make bump steer behaviour worse). Relatively tiny little adjustments having been made - the car is now completely different. Was horrifying how much it wanted to steer from the rear on any significant single wheel bump/dip. And it was even bad on expansion joints on long sweepers on freeway entry/exits, which are notionally hitting both rear wheels at the same time. My point is, the crappy Nissan multilink is quite sensitive to these things (unlike the very nice Toyota suspension!). And I think 99.75% of Skyline owners are blissfully ignorant of what they are driving around on. Sadly, it is a non-trivial exercise to set up to measure and correct bump steer. I am happy to show my rig, which involves nasty chunks of wood bolted to the hub, mirrors, lasers, graph paper targets and other horrors. Just in case anyone wants to see how it is done. I'll just have to set it up to take the photos.
    • What do you have in that bad boy ? Ill go with the 725cc since I'll be going with Nistune ( would definitely like more engine protection but Haltech is too far out of reach at the moment... plus, Ill probably have a pretty safe tune as its a daily, not gonna be chasing peak power 24/7 ahahah ). Are Xspurt a safe choice?  Pete's great. He didnt mention anything about traction arm length so I reckon it may be good. When I get some new wheels/tire later down the road I'll ask him about it and get his opinion on em. I heard from Gary that you've got the bilsteins too, are you running the sway bars too? and what other suspension goodies do you have installed or would recommend?
    • In true Gregging style...
