  • Replies 62.7k
  • chaos
    7164
  • Ska
    5791
  • BelGarion
    3645
  • Nexus9
    3590
Cyrus... Call ur nearest ABS store...
I negotiated them down to do mine for $645... But couldnt get it done today now :(
Brand new daiken exceedy HD clutch, all bearings, flywheel machining the lot :)
Cool well done, am going to wait for Gav to get back to me, Amanda is going to ring around and see what the best price they can do for me, see what they can do then call ABS :D
I bought James's old stock BOV for my GTST yesterday since he no longer requires it. I have never had a re-circ tyoe bov on the GTST in the 2.75 yrs of ownership, How much better does it run. Nice crisp return to idle when you come of throttle, no snap, crackle, pop between gears not to mention sounding completely different to drive. Might have to get my finger out to fit the stocker onto the GTR, much bigger job though. THANKS JAMES, if you ever log on today.
hay matty,
have been kind of busy this week.  I really shouldn't be whoring right now but I just can't help myself.  How's your week been?
Yeah i've actually been busy, had a few things come up which are pissing me off...
COuldnt get my clutch done today in the end and im going away on friday, so It will have to wait :P
im in a shitty mood lol
hey jason.  How did the ankle heal up in the end?   And how is the R running?
Ankle still sux, at least I can get around now without a drama, just can't move it out of its comforts zone otherwise it really lets me know, still doing physio twice a week. R is good touch wood, there seems to be alot going BANG! at the moment, kinda scary when I bought mine from an auction slip.
So the difference of a BOV change is that noticable? wow... you hear so many people say they are for show... glad they are wrong because I love my BOV :P
Yeah, but I was going back to a stock one though. I am pretty sure the atmo one on the car when I got it was a no frills version though, looks pretty budjet.
Guest
    • Not R7R. Meant to type R&R, obviously enough.
    • Bugger "making it look stock". I put one conventional internally fused Hella relay behind each globe. I just pulled the plugs off the back of the globes and built new loom segments with male and female plug parts to match up to the original loom and the globe, and used the original power wires to each globe coming from the switch through the original loom plug to trigger the relays. Ran a big fat (also separately fused) power wire across the front of the car to feed all the relays. It's as ugly as f**k, but it is wedged down between the headlight and battery on the RHS and the airbox and headlight on the LHS, and no-one ever looks in my engine bay, and on the odd occasion that they do I simply give no f**ks for what they think. Fully reversible - not that you'd ever want to. For f**k's sake. It's a Skyline. They made million of the bloody things. We've been crashing them into roadside furniture for 30 years now. There is a negative side effect to putting relays on the headlights. The coil current is too little to properly clean the contacts in the switches and they get blacked up and you have to open them up every couple of years and clean them manually. I have 25 years of experience on this point.
    • I was poking through the R34 wiring diagrams vs R33 and noticed that the R34 has proper headlight relays while the R33 is like the R32 and sends full headlight power through the headlight switch. I'm not afraid of wiring but I really would like to do this in a way that looks OEM (clipping into open positions on the OEM relay box) and also unlike the factory wiring which interlocks the high beam and low beam on the halogen series 1 GTR headlights I want to make it such that turning on the high beams keeps the low beams on as well. Any advice on how to locate the specific connectors + crimp terminals + relays I need? I was thinking one NO relay for low beams and another for combined high + low running off the factory high beam headlight connector. I don't really want to splice into a crusty old probably discontinued factory harness so fully reversible is my goal here.
    • Pretty sure they run the same engine as the Q50 hybrid which specifies 95 RON.  I ran 98 in mine for a while, but it made no difference in performance or economy, so I have been using 95 for the last few years.  I have never hit 6.0L/100km, but have returned mid to high 6 on the highway.  Being a hybrid, fuel economy is a lot more dependant on how you drive it.  At 110km/h, mine never goes into EV mode on the highway, so returns closer to 7.5L/100. urban driving can return low 8s if you are careful or over 10 if you are a bit more enthusiastic on the throttle.
    • About a quarter of what you want to do. It's only R7R, not R&dismantle&replaceparts&reassemble&R. ? It is stock. I already told you, you will NOT have broken those. It's f**king 4th gear for Christ's sake. You just chipped the teeth off.
