  • Replies 62.7k
  • chaos
    7164
  • Ska
    5791
  • BelGarion
    3645
  • Nexus9
    3590
Afternoon all....
Just thought I would let you know about a little incident I had the other day (in Woodridge).
Stopped in to pick something up from a shop cause it was cheaper than anywhere else and was only there for 10 minutes.... Came out and the GT badges from the sides had disappeared. NOT HAPPY JAN! Good old Woodridge.
Does anyone have any spare?? or know of how much they cost. Am currently doing a search at Just Jap etc...
aside: i am selling 33nizs front bar :P
anyone interested
:jk:
Makes note: Send mafia people to Neils house...
On a serious note, my new bonnet etc should arrive today..finally be able to get it all put on.....soonish!! hooray!
oh well you can take it and cram it, i wont be back
Want a tissue?
That goes for the rest of you also.
I don't see the problem here, we have different people that go out for different things? The problem here is what???
Woopiddy do I drive on Mountains, Woopiddy do I drive on the Highway, Woopiddy do I park my car and talk...
Stop being Tonkas and enjoy your bloody cars.
Gordo, you haven't made your cruise quota this quarter and you can't be my friend or talk to me on the forums. Until you fill this quota.
:P
screw you hippy! can't talk to you hey..hmmm.. what am i doing now huh huh? p
Want a tissue?
:werd:
i stilll don't even know what the issue is.. :confused: peace love and mung beans
anyhow.. hey rasi - you can get thm from justjap.. but they are wee expensive - $45 EACH i think.. i got them but i felt so cheated paying that much for a bit of plastic
:P
I'm just saying you can't join my 1337 crew that at the moment includes, well me. because you are simply not 1337 enough. I meant If you say anything to Me I won't bother typing out a response, I will just ignore you. also You IGNORED my taunts yesterday on the whoretown. I was so crushed and hurt.
Jay I think I'll take you up on that tissue offer.
Guest
    • Pretty much what you'd expect at that power level. Hypergear turbo, long list of supporting mods, full Haltech catalogue, etc.  I'd say this goes for most drivers, suspension is still a dark art for most people. And it's really hard to convince someone how much better their setup could be...
    • They are what I will be installing. 640s for me.
    • Hmm... From my experience you get about 0.25° camber change per mm of RUCA length change. So, to correct from -2.5 up to less than -1° (or, more than -1° if you look at the world as a mathematician does) then you'd be making 6-8mm of length change on the RUCA. From a stock length of 308mm, that's 2-2.5% difference in RUCA length. My RUCAs are currently very close to stock length - certainly only 2-3mm different from stock. I had to adjust my tension arms by 6mm to minimise the bump steer. That's 6mm out of 210, which is 2.8%. That's a 2.8% change on those, compared to a <1% change on the RUCAs. So the stock geometry already has worse bump steer than is possible - you can improve it even if you don't change the RUCA length. If you lengthen the RUCAs at all, then you will definitely be adding bump steer. Again, with my car, I recently had an unpleasant amount of bump steer, stemming from a number of things that happened one after another without me having an opportunity to correct for them. I only had to change the tension arm lengths by 1mm to minimise the resulting bump steer. (Granted, I also had to dial out a lot of extra toe-in in the rear, and excessive rear toe-in will make bump steer behaviour worse). Relatively tiny little adjustments having been made - the car is now completely different. Was horrifying how much it wanted to steer from the rear on any significant single wheel bump/dip. And it was even bad on expansion joints on long sweepers on freeway entry/exits, which are notionally hitting both rear wheels at the same time. My point is, the crappy Nissan multilink is quite sensitive to these things (unlike the very nice Toyota suspension!). And I think 99.75% of Skyline owners are blissfully ignorant of what they are driving around on. Sadly, it is a non-trivial exercise to set up to measure and correct bump steer. I am happy to show my rig, which involves nasty chunks of wood bolted to the hub, mirrors, lasers, graph paper targets and other horrors. Just in case anyone wants to see how it is done. I'll just have to set it up to take the photos.
    • What do you have in that bad boy ? Ill go with the 725cc since I'll be going with Nistune ( would definitely like more engine protection but Haltech is too far out of reach at the moment... plus, Ill probably have a pretty safe tune as its a daily, not gonna be chasing peak power 24/7 ahahah ). Are Xspurt a safe choice?  Pete's great. He didnt mention anything about traction arm length so I reckon it may be good. When I get some new wheels/tire later down the road I'll ask him about it and get his opinion on em. I heard from Gary that you've got the bilsteins too, are you running the sway bars too? and what other suspension goodies do you have installed or would recommend?
    • In true Gregging style...
