QLD Whoretown...
predator
 Share
i shouldnt have spent heaps on this sony cd player heh oh well......i got sick of listening to distorted radio, and ive got a pair of sony subs sitting at home thats been neglected for about a year.
  • Replies 62.7k
  • chaos
    7164
  • Ska
    5791
  • BelGarion
    3645
  • Nexus9
    3590
i got:
hks fmic type s
hks ex. cam gear
hks boost controller
full 3 exhaust
pod
powerfc
around 180 -190rwkw @ 12psi i guess. nismogirl's made 198rwkw @ 14.5psi on the same dyno as mine will be tuned on.
im currently researching turbos atm. havent gotten deep into it but im lookig in the direction of a hks 2835pro s. bit expensive i think, and i rekon i could get something similar here for alot less. also looking into what else i need. im thinking:
550cc inj.
bigger fuel rail (?)
f p reg. (?)
fuel pump
some exhaust/intake pipework.
ex. manifold
looking for 270rwkw on light boost. then internals and lets go boost! but then its clutch and a few other things as well. gets very expensive eh.
decent suspension above all really. its shocking atm. king springs on stock struts. :eek:
i think i will have to. power is nothing without driving skill. ive never been on a proper strip before so i'll be pretty nervous i think :D but it'll be good fun. what time you rekon from those mods? my biggest problem is 18" rims and a 35 profile tyre. might get the stock ones widened. i think its good for a 13.5-14.0...
pump close to the limit? i didnt know that. might get one in before the tune if possible.. i understand a good pump will push the stock injectors that little bit further too. from like 370 - 410cc
Guest
 Share
    • People still have Skylines? I thought they're non-existent now.
    • Harness update time have had great fun and learnt so much already so far with this project. I started off making both the ignition and injector sub harnesses in the hope any mistakes i made here aren't as hard to undo and learn from as the main harness.  A cool comparison of the old harness using presumably TXL wire and the new which is using Tezel. Also opted to use DTM plugs to keep the whole setup as neat and tidy as possible and tucked the wiring under the coil bracket to try and keep it all from sticking out too much. Although the injector harness, I'm not overly happy with as I'm still using the rubber boots that are supplied with the type of plugs it just looks ugly and sticks out like a sore thumb with the white identifiers so a slight redesign may be done.   Then it was main harness time and most importantly trying to route it nice and away from the heat it will use the OEM heater hose routing which is no longer present to keep the harness up high and secure. it's amazing how much smaller this harness is able to be compared to the old one. plugged everything into the emtron and with the help of the tuner again attempted to start it up and instantly fired up and running smoothly on all 6 which was a big shock to myself. So still some routing and adjusting to be done for the final fit up and installing a knock sensor harness plug which is in the post all has gone surprisingly well.     The old harness for shits and giggles.
    • They do that at random every now and then, with almost no detectable cause. Mine has done it a couple of times (over 25 years!!). Never worked out why.
    • I don't post on here and have been lurking for some time now. Many of the topics have helped me out more times than i can count. I was racing yesterday (11/9) and blew a front right CV shaft. I have spares so I popped a new one in. A thread i read previously said to check the engine mounts if you blow a front CV. Upon inspection, the front right mount was completely separated from the upper plate. This discovery saved me time and money, because i would have blown another CV if i went back out. Just wanted to thank you guys and wish everyone luck with with their builds. (Now if we could only come up with a solution for my power steering belt flying off after hitting the rev limiter, lol)
    • Either way he still need those style of spacer to go into the manifold because the photo he currently has is not going to work
