  • Replies 62.7k
  • chaos
    7164
  • Ska
    5791
  • BelGarion
    3645
  • Nexus9
    3590
awesome..
if it is still registered and has just lapsed, just tell the coppers you have paid it, and it mustn've gone through. To be honest though, i think unless a cop had actualyl pulled you over they wouldn't notice.
Even when i got pulled over at nebo a few months ago, i still had no rego sticker on there and the cops didn't even blink or raise a question aobut it.
My night was a bit rough... alot of family stuff going on atm.
Then I went to buy cigs from the servo and noticed a ute had ploughed into a huge tree on the way home, I stopped and called the police, no one was in the car, but there was stuff on the seats which I wont talk about in public... Then I heard rustling in the bushes and the 000 operator told me to leave...
How about you james?
what the? i've always dreaded having to witness or be the first at the scene at an accident. I know you have to stop.. but what you see my haunt you for your whole life.
hope you're ok man.. family stuff can be tough.
Yeah thanks gordo, im ok with the family stuff.
I was packing it when walking up behind the car that there would be someone unconsious in the drivers seat or even worse... But yeah you do have to stop, it could save someones life...
THe lame thing was that people were going up the other side of the road, slowing down to look, but driving off... Queenslanders suck in that way, as I found out when I hit the pole...
Guest
    • I don’t really have any ideas how to set the timing on the CAS 😂, sounds like the top, sounds like it maybe misfiring as well as ticking,  got the box sorted 😌, must of been a air bubble on the clutch side
    • Use a 2' length of hose (that's 2 foot, not 2 inches) as a stethoscope to localise the source of the ticking. From cam covers? From exhaust or turbo manifold gasket? From injectors? From lower down in the engine? Etc. Use a timing light to set the timing. Put Redline Lightweight Shockproof in the box. It's not the very best thing for the box, but it will take a box that refuses to engage a gear with other oil, and make it engage a gear. I had to put it in when I installed the R33 box I have in my car. It would not select ANY gear when running. Smurf jizz made it work. That was >10 years ago and I still use it. I'm stuck with it now. Failing that - rebuild the box.
    • Well done Duncan. The fuel tank bulkhead lid is also in great condition (some of mine were stuffed). These are now out of production and good ones like that are becoming hard to come by.
    • Wow that's a steal, you've done well there.
    • Exterior LEDs R34 2Dr R34 4Dr Position Lamp T10 T10 Winker front T20S T20S side T10 T10 rear T20S S25S150 Anti-hyfla relay TYPE3 TYPE3 tail T10 T20W Stop Lamps T20W T20W High Mount T16 T16 back T16 T20S number T10 T10 trunk T10 T10 Interior LED Item No.     Map Lamp BA9S single-sided     Room Lamps T10×31     Trunk Lamp T10     meter Early T6.5 pedestal     final T6.5 pedestal     NISMO T6.5 pedestal     Liquid crystal section T6.5 pedestal     Winker T6.5 pedestal     High Beam T6.5 pedestal     3 SERIES METER Early T6.5 pedestal     final T6.5 pedestal     NISMO T6.5 pedestal     air conditioner Early Liquid Crystal T3     Late LCD T4.2 Short     button T4.2 Middle     Hazard SW T3 Pedestal Short     Keyring T5     Cigar Socket T5
