  • Replies 62.7k
  • chaos
    7164
  • Ska
    5791
  • BelGarion
    3645
  • Nexus9
    3590
Just to inform you all, Team Shitbox is NOT anything to do with boostcruising at all.
It's a website that andrew has set up from scratch (learnt PHP) and it was his first ever attempt at making a webpage from the ground up. He decided we would get it hosted on the net for people who started team shitbox to participate in a forum.
*I* pay for this website and if any of you have any further derogatory comments to make about the website, it will result in a personal attack warning on who ever comments further. :rofl:
They aren't all shitboxes either. If you want to get pandantic with things, my skyline is part of "team shitbox" and so is Dave's cefiro, so is an 12sec WRX with the plates SHERIF that you may have seen around the traps, so is 16OTU which is an 11.3 sec Gemini who frequents the cruising scene.
why is it called "team shitbox" then :rofl:
wasnt there a crew of people that did actually have shitboxes out there? like $500 crappers.. or in fact like my r31 :rofl:
I'm glad you feel the love gordo. and Btw this has got to be by far the SADDEST converstion we have had on here in a very long time.
nah.. nowhere close.. remember that time when you stuck the gerbil down your pants when i dared you a lollypop and i distributed in kazzaa all over the internet? and you cried, and told your mummy.. and my mummy told your mummy she was a ****??
Wtf? are you serious? If we, as a group of car onwers cannot disscuss another group of car owners openly without you taking offence, then I don't think you should be moderating here...
I think it's shit.
In a box.
That races.
such fragile nerves on here.. i think its a bit poor if you can't openly just speak rubbish without somebody getting their knickers in a knot.
that borders on censorship.. and if we live in a sensored state we may as well go dig Saddam out of jail and make HIM a moderator.
easy....
Guest
    • I don't think the shuffle can damage the turbos. It only happens at low shaft speeds and loads. It's just annoying (to some people - others are tickled by the effect) and it quite possibly reduces spool performance a little bit.
    • Oh dear. The panel beating needs to be done before the filler work. Do you have a photo of the dent before you started? Hard enough to not flex and only hit the high spots?  What do you mean it was just temporary?
    • Can u check this way it works for power supply?
    • These coils draw 10amps that what i read online
    • I appreciate the detailed explanation, think I understand now. I spent the better part of last night reading what I could about shuffle and potential solutions. I had replaced the OEM twin turbo pipe with an alternate Y pipe that is separated further away from the turbo. The current one is from HKS and I had a previous pipe that was separated even further away, both have shuffle. I had heard that a divider can be welded in to the OEM pipe to remove turbulence, and figure that aftermarket pipes that are more separated would achieve the same thing. From what I read, most people with -10 turbos get shuffle due to their size, though it's a bit less common with -5s on a standard RB26. I think Nismoid mentioned somewhere it's because OEM recirculation piping is common in Australia with -5 cars. It seems that the recommendation tends to vary between a few options, which I've ordered in what I think is most feasible for me:  1. Retune the MAP or boost controller to try to eliminate shuffle 2. Install OEM recirculation piping 3. Something called a 'balance pipe' welded onto the exhaust manifolds. I don't know if kits for this are available, seems like pure fabrication work 4. simply go single turbo My current layout is as follows: Garrett 2860 -5s HKS Racing Suction intake MAF delete pipes HKS racing chamber intake piping hard intercooler piping,  ARC intercooler HKS SSQV BOV and pipe Haltech 2500 elite ECU and boost solenoid/controller HPI dump pipes OEM exhaust manifolds HKS VCAM step 1 and supporting head modifications Built 2.6 bottom end All OEM recirculation piping was removed, relevant areas sealed off I'll keep an eye out for any alternative solutions but can get started with this.  Only other question is, does shuffle harm the turbo (or anything else)? It seems like some people say your turbo shafts will explode because of the opposing forces after a while and others say they just live with it and adjust their pedal foot accordingly.
