  • Replies 62.7k
  • chaos
    7164
  • Ska
    5791
  • BelGarion
    3645
  • Nexus9
    3590
was just wondering why society frowns upon the devotion of real anorexics, and in saying that I mean the ones with suficcient devotion to starve themselves thin, and yet society proclaims ad good and just the same sort of madness that it takes to be brilliant and churn out straight sevens at university. Was at a graduation ceremony for honours a while ago and the dux of the class had a gpa of 7 which means she didn't get anything but 7's for the whole degree.
In this day and age of obecity I think we should champion Anorexics with the devotion to stick with it, and frown upon the obece that lack the self discipline to get with the program.
thoughts chris.
Who says that the obese are no less driven than an anorexic?
I would assume that the same disorder that requires/allows you to absolutely destroy yourself would be applicable to a morbidly obese person too.
I don't think that your avaerage person is capable of the dedication that it would take to be corpulent to the same reverse degree.
Any excessiveness is frowned upon by society for good reason, whether it is anorexia, obesity, workaholism, greed, etc, etc.
Different sides of the same coin.
This person who had a high GPA across the board, is there any moderation in this persons life or did they devote everything they had to atttaining those marks?
Sure good marks would indicate a successful future, but against what measure? High paying job but no life outside that job (i.e die alone but rich).
Moderation is the key, but it is so easy to lose sight of.
1. The obece are not driven. Often obecity comes out of a sedentary lifestyle and lazyness more than anythine else. Also the undereducated are far more likely to be obece than the well educated and more fortunate. It tends to be a dizease of the lower calsses and the less socioeconomically endowed groups of society but times they are a changing and that no longer rings true.
2. Thus these people are the ones with devotion. We should really take them around to schools as motivational speakers
3. excessiveness in terms of finding a solution to a problem or artwork tends to be champpioned. Many of the great artists and poets of the world were mentally unwell and yet we appreciate their work.
yes granted everything has a price.
I think another point is how society can turn a blind eye to its set of double standards and the question of how our value system became so skewed. Once again we are brought back to the question of intent and the idea of doing all the right things for all the wrong reasons.
don't know if you'll read this but thanks for the effort in your response.
Guest
    • Yes, but it's not as easy as pulling a fuse on anything other than an R32. There's a routine you have to do, involving disconnecting a loom plug and bleeding down the preload.
    • A question for tuning awd, is it possible to disable the AWD? The stagea is an EA/T AWD, Toshi had said on a GTR, he was able to disable it and make it 2wd. Just wanted to double check if this was possible
    • Whoa, that's a name I've not see for a long time! Sorry to hear about the engine / turbo damage.  Fwiw with any engine problems it often really a case of just seeing what happens when it's apart, ymmv - I wouldn't rule out the possibility that the damage isn't even from the turbo failure, or possibly from a combination.  The airflow between cylinders isn't dead even, injectors can go off over time as well, with the turbos overboosting if you didn't have upgraded fuel system there could have possibly been a bit of leaning out - stock triggering is often a bit unreliable by this age too.  Basically its an old engine and a few things could have been going on, and you won't know how much work is needed until the engine is apart.
    • I'm just shocked there's a euro driver on our roads who is thinking of other road users and not attempting to blind everyone. I wonder if Prank uses his indicator too...
    • Its hard to tell really. The Q50 owner's forum talks about it a lot and has quite a few people directly affected, but no idea what % of cars sold actually had the block replaced. Also, there seem to be 2 distinct issues which both get diagnosed by Infiniti as requiring a block replacement (no wonder they are going broke) 1. "Porous block" where coolant mixes with oil through thin or poorly cast parts of the block 2. Head coolant gallery plugs not sealing. If I was noticing engine coolant loss I'd start with cooling system pressure test (as always) and then I'd pull the cam covers and reseal the coolant gallery plugs on both side before worrying about a potentially porous block.  If neither of those did the trick it would be put in a second hand engine out of japan; I haven't checked pricing but I'm sure there are plenty around by now as they've been in production 10+ years
