  • Replies 62.7k
  • chaos
    7164
  • Ska
    5791
  • BelGarion
    3645
  • Nexus9
    3590
nah.. there are just plenty of ****ing spanner tool wankers in 4WD on the M1.. even just driving around during peak hour (where there are generally less psychopaths on the road) they can act like utter ****wits, sitting right up your ass and everything else..
i think 4WD owners have something against the average import, or in fact anything not a 4WD.. wankers
But I would argue that the average man is now more uneducated that ever to learn for themselves, and in fact less in charge of his own free will and conscious decision that ever before in todays world. Outside inference and the desire to conform will always restrict human freedom and ability to learn for oneself.
With mass marketing, mass culture, and a global worldspace, the individual has less rights to express their individuality than ever before. Without taking heavy cues from outside stimuli, the presentation of that stimuli is cleverly wrapped in modern euphenisms and brandism presented through mass media, the individual has lost the ability to think for their own without looking to outside cues. Even these 'unconscious' thoughts that we all have are in fact filtered through multiple streams and traffic light systems enforced by todays society.
What is truly my thought? what is truly your thought? or what has really been prepackaged and wrapped up into how we should think, how we should act and how we should behave given certain circumstance?
wow gordon!
Thats some university lecture material, i think thats the smartest thing thats ever been posted in wasteland
Guest
    • Both windows operate normally while the engine is running but start to sag as soon as I switch off.  Does anyone know of reasonably priced replacements or other brands that will fit?
    • Actually PowerFC is probably the easiest to get basic data from, it comes with a hand controller and display so you don't need to remember to pack a laptop every time you drive. It also has a PC based viewing/logging option if required. Nissan used consult on these because back in the mid 80s, ODB was just a glint in a standard's body's eyes.  They switched to OBD shape around 2000 (my 2001 Cima had OBD shaped but not OBD compliant port) With the standard ECU there is a cable and software available to give basic data too, I think it is called Nissan Data Scan or s
    • Given by the sheer number of questions about offset, absolutely not. If you had the information formatted this way: Space from R34 GTT hub to outer arch = 100mm Space from R34 GTT inner hub to nearest suspension arm = 90mm. (making this up) Buying a wheel that was advertised as Enkei RPZ5 Diameter 18in Width 9 Distance to arch = 84mm Distance to suspension arm = 76mm 100% of people would know instantly if it fits. They would absolutely also know instantly how close it fits too, and no questions would need to be asked. You would know you would have 16mm from the guard and 14mm from the suspension arm.
    • Ah ok, for example for the apexi ecu I heard that it's pretty limited with the information it can give you. Also not sure why Nissan used the consult port over the obd2, what the idea there was.
    • Diagnosing with and without is mostly the same. You need to know, as Duncan asked, and what conditions. Car hot, cold, idling, driving, if while driving what rpms, is when you're varying, or is it when held constant.   From there it's understanding what can be causing it. Starting with pretending all of the sensors are correct. Which means if it's going rich, why would it be thinking more air is going in than it is, and under what conditions. So things like if only when under boost, it could be be a loose intake piping joint. It's just understanding the system, and understanding when/how the problem occurs, and then if it's only occuring in specific scenarios, what can be causing it.   ECU specifically, if it's aftermarket, it'll have software you can use, for the Skylines on factory ECU, there is Nissan Consult you can use. Most ECUs have a way to get data from them.
