  • Replies 62.7k
  • chaos
    7164
  • Ska
    5791
  • BelGarion
    3645
  • Nexus9
    3590
I'm fairly confident the stars are still up there nexus.
heheh
I know but with all the lighting and smog you don't get to see many nowadays over the city.
And if I can see them all in half an hour in the comfort of a armchair, well I say bring it on
Voodoo Lights was originally written for a 3dFX competition.
Some dude still writes it very occasionally.
Its a screen saver to whup the ass of every half-assed screen saver and winamp visualization EVER...
Download it. Watch it. Smoke some drugs and watch it again.
Very cool.
Guest
