AHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHH
It's friggin raining!?!?!??!?!?!?!?!??!
a little rain never hurt anyone...it will just challenge your elite mechanical skills. Now you will have to include an unbrella holder eh? lol
  • Replies 62.7k
  • chaos
    7164
  • Ska
    5791
  • BelGarion
    3645
  • Nexus9
    3590
UUUMMMMM ........bout a week and a half , maybe after next weekend
Will only get to drive it for a few days then going down to Sydney for a week or more , then it will only be a week until skid pan day WOOHOO.
Are we putting in a club entry for Autosalon ??? I think it is like the same weekend as SAU QLD day
Yeap, got big ruble and bleed valve, just now boost guage xcept the stocker so aint gonna play round with it until I get something that can acuratly show what boos I am running!
Thats a good idea, I wish I had of thought of that :D :D
How good was my idea? Eh? Eh? Damn good idea.
Note: Boost controller getting power from stock boost controller power supply.
Means: Low boost setting (reccomend 9psi) until 4500rpm, high boost (reccomend 12psi) from 4500rpm onward.
By running a parallel neutral into the cabin, you can switch it for constant high boost too if you wanted.
Guest
    • Nope. The seal is in the drive. A new cable would just fill up and continue to convey oil to the speedo head. To check if this is what is happening, take the cluster out, dismantle the speedo and have a look. You probably don't even have to dismantle it. If there is oil coming up the cable, the drive into the speedo will be grossly greasy. I had to manually (and delicately) clean the gunk out of my speedo.
    • Thanks for the quick response mate, and I agree Nismo 555s, Z32 and high flow 2871 in OP6 housing (run by PowerFC) would all be "period correct" and should be a simple, reliable and reasonably quick track car.
    • It is normal for a speedo to read 0-10% high (unfortunately), intended by manufacturers and ADRs (although not in this case) to ensure your speedo does not read low if your tyres are worn. Speaking of which, what size tyres do you have on the rear, and what does they tyre placard say you should have? you can use this https://tiresize.com/calculator/ to determine what % difference that is causing Personally, when I buy tyres for a car I buy a size that will bring the speedo back to being more accurate; it if it reads 5% high I buy tyres that are 5% larger diameter. If you had an electronic speed sender like R33 onwards, the other option is to add a speedo adjuster but that won't work in R32. Finally, you  might be able to find a different sized gear for the speedo sender but that will be limited to what already exists (and I don't know what sizes do)
    • OK...so dumb question to check....do the hi beams actually come on when the push the stalk to engage them (keeping in mind your headlight switch must be at ON as well)
    • Nah it factory manual not sure about ratio but it looks like there’s been some work at the rear
