Any ideas on how to get around them?
Even on perfect CDs I get them.
Tried ripping at every available speed from 1.00X to 32.00X.
Tried EAC, Audiocatalyst, iTunes, even copying the WAV files with random programs then using Audiocatalyst to convert to mp3.
Tried several different encoders (including all bitrates between 128 and 320k)
Sorta running out of ideas... maybe the cdrom is just sh1t? Aopen 52x32x52...
where r u getting the tracks from because it will most likely be from the sorce & if so u are not going to get rid of em :Bang:
  • Replies 62.7k
  • chaos
    7164
  • Ska
    5791
  • BelGarion
    3645
  • Nexus9
    3590
hey mike.. waz up?
well now i sold my r33 i might do some stuff on the r31..
might come this weekend to see what i might buy off your wreck. at the moment the only thing that is really bothering me is the odometer stopping about a month ago.. but i just need the little bit inside the cluster. its hard to explain.
rest not sure. one minute some of the worn stuff bothers me, at others its just extra character :D
I got around them by creating an iso image of the cd using alcohol 120%, using isobuster to correct any "errors" Using Daemon tools to run the corrected iso image then using Musicmatch Jukebox to rip them.
Pain in the arse but it worked for me
probably :D is the pops playing on every device u try and play it back on?
i never have had probs? i was using a pioneer drive to rip them though?
oh them..
from what i remember i think i just used nero to extract each track as WAV's.. then fed thru musicmatch to generate the mp3 ... worked fine using the pioneer. I think some drives must just be more sensitive to the protection than others?
i think it was how i did it on a couple of cds anyhow.. but i forget. they could have brought out even newer protection.
Guest
    • Hey all, I'm sorry if this has been discussed before.  I have a 2008 Japanese import V36 coupe with nav but without Bose. I bought one of those AliExpress android screens, which for the most part works really well.  The only thing that doesn't work is the air con controls (well sort of) and the factory reverse camera.  The AC can be controlled fine but it doesn't report the change in temp and mode to the screen, and the volume knob/other audio controls from the panel don't register on the learning app.  I am pretty certain that the problem is the difference in the head unit between base model (Nav but no Bose) 2007-2009 coupes and anything after 2009.  Mine is the one with the blue connector all the way to the right as seen in this forum post:  The reason I think this is there is one wire left over that doesn't fit anywhere on this head unit, or in the factory screen which also uses different connectors to more recent versions.  I've seen the upgrade from OWC, and have sent the guy a message on eBay but no response yet.  I also don't particularly need the whole kit, just *maybe* an adapter for this one cable.  Did anyone else here have the same problem, or have any insight about what I can do to get this working?  I have been in contact with the seller but all they seem to be able to do is ask for more pictures and videos. Minor edit to add:  I have been researching and found a screen on Aliexpress that actually specifies my head unit in the listing, so these things do exist.  I will contact the seller to see if the wiring adapters are interchangeable with other screens.   Thanks in advance!
    • Can't go wrong with tourings/estates/wagons.
    • Oh poop ! I missed the "deposit" in your post !
    • I laughed so hard a snot bubble popped out my nose !  And seriously ! You can still buy a decent house in Western Sydney for 2 mill ? ?
    • Come on guys, they're just trying to sell their project car to scrape together a house deposit in the Western Suburbs of Sydney...
