  • Replies 62.7k
  • chaos
    7164
  • Ska
    5791
  • BelGarion
    3645
  • Nexus9
    3590
/looks around.. did somebody mention *beer* ?? :D
yeah, while its tempting to take the cheaper option. I think its probably a good idea in this case to get it repaired professionally, it is your steering afterall and an important part of the safety, etc of the car.
If you can track down a 2nd hand control arm, would you be able to just replace the bushes?? They are just rubber doova-hickeys aren't they?
Guest
    • Kaizo Industries put a VIN plate over where the Nissan plate would go. It was part of how they broke the law and attracted feds going after them.
