  • Replies 62.7k
  • chaos
    7164
  • Ska
    5791
  • BelGarion
    3645
  • Nexus9
    3590
safety...
yeah, thats the other possibility i guess, running to rich and just flooding the plugs so they get clogged easily. Although i would have thought it would be leaning out. Actually Cyrus: why *are* you trying to go above 10psi with stock cooler and stock ECU = badness.. summer will hurt you.
safety...
well this not only happens at over 10psi, on rare occasions it happens around 7-8 psi, under open throttle conditions, meh I dont really want that, be good if I could turn the turbo off for a while as i will be riding to work for a couple weeks seen I want to pay Beau off as fast as possible.
Damn petrol being>$1/ltr, sucks to own a turbo car :P
search function is my freind:
In my opinion the big advantage of the SAFC 11 is the ability to tune part throttle A/F ratios separately from full throttle A/F ratios. With earlier versions the tuner had to compromise, eg; too rich at part throttle to get full throttle OK. This affected fuel economy if you compromised rich and risked engine damage if you compromised lean. With an SAFC 11 you can have a bit of cake and eat it too. Not all the cake though, that's full ECU (as in Power FC) territory.
The SAFC1 's have great extrapolation though, so the lower number of load points is not as big a handicap as some make out.
Skylines run closed loop, therefore if you don't boost the car the AFR's should be 14:1 and won't use much petrol:D
Yeah I am running a turbosmart bleed valve boost controller and after this thursday i am going to turn it down as low as i can go, which is 7psi according to our local hero, i didnt really understand what all this talk about wastegates and dunno really how turbos work, so I didnt argue with him :P
Guest
    • I do have their “Nissanie Motorsports Co.” vin plates, but I am curious if anyone would have more info on them. Like how many cars they’ve imported and whatnot
    • Been a long while since i have updated this money pit lol.  Have had a few tune related issues with the car, first blowing the frost plug out the back of the head and then blowing the headgasket 3 months later, which has now been retuned and sorted. Done a few little changes along the way as well, i wasn't happy with the wheel and brake setup, so start of last year i managed to get myself a set of r35 brakes and nismo lmgt4 18x10.5 +15 Upgraded to now running a Precision Gen 2 6870 with a 1.15ar, to be honest felt more like a downgrade as the car feels much lazier around town compared to the Gen2 6466 previously. 0761719E-5683-43F7-BD3B-4BD94335DFF4.mov
    • Hi there, i am currently using the Elmers Racing Billet merge collector, we are using sch40 tubing and 1.5" ID, no cracks so far. however if i was to do it again, i would go sch10 with 1.25" runners
    • I haven't touched the turbos so might need to look at that 👍 Appreciated 🙏
    • If you haven't replaced the OEM turbos, replace them sooner than later. I have seen recent pictures of what OEM ceramic turbo failure can do in an RB26 and it will make a 10k AUD budget look like a joke. Single vs twins have been done to death on this forum. If your turbos haven't fallen apart you can probably send yours off to Hypergear for rebuild. The journal bearing option will have more turbo lag but it's a good bit cheaper. I would probably go for ball bearing CHRA but keep in mind ball bearing turbos are more particular about oil pressure/flow.
