  • Replies 62.7k
  • chaos
    7164
  • Ska
    5791
  • BelGarion
    3645
  • Nexus9
    3590
I wish you guys/gals lived closer, cause I'd come round and help
Ok then ;).. we had a play around a couple of hours ago .. riddle me this:
- coil packs swapped for complete other set
- spark plugs seem to be "about 0.8mm" (left feeler guage at home - oops) and were all fairly recently replaced.. NGK BCP6RES which i think come out these days stock at 0.8
- no obvious air leaks, split, or disconnect vacuum pipes
Which in my mind only could leave?
- Timing slightly out (couldn't check)
- not running cooler or aftermarket management which i know is a bit iffy at 10psi (although apparently it does it at stock boost levels too)
- ignition module (doubt it)
... OR ????
Running about 10psi boost, few random misses at around 4000rpm.. but can "push" thru till they start appearing at 5500rpm or so again. Not massive (heard worse) but enough to shit you when going hard.
So Dr Paul - what is your prognosis?
This is Ska's ka (oo that rhymes)... nah.. no SAFC .. no nothing - that is why I think its maybe a bit iffy even trying to wind the boost up on that setup. No real sign of audible pinging though. Actually almost seems to be the opposite... could it could be just running a bit rich, flooding the cylinders??
0.64mm ? interesting... he could try that.
I always used to run BCP6RES w/ 0.8mm on the rb25det and never had miss issues 10degrees or 35degrees.. but i did have a big front mount and SAFC.
well at least i found out my "spare" coilpacks work.
Guest
    • Hows your intake piping? Are you still running stock? Having in the stock AFM position would mean, if the BOV was shut/venting out, it'd create the almost stalling kind of effect right // "the rich pulse behaviour" due to MAF thinking air is flowing ? But this would be better than having the bov in the stock position + MAF on/just before cross over piping right?
    • Essentially, yes. Although I wouldn't put the AFM on the crossover pipe. I'd want to put it into what amounts to the correct size tube, which is more easily done in the intercooler pipework. I bought a mount tube for card stile AFM that replaces the stock AFM - although being a cheap AliExpress knockoff, it had not flange and I had to make and weld my own. But it is the same length and diameter as the stock RB AFM, goes on my airbox, etc etc. I don't have a sick enough rig to warrant anything different, and the swap will take 5 minutes (when I finally get around to it and the injectors & the dyno tune).
    • So to summarise, the best thing to do is to move recirc to between turbo and IC, and maf on the crossover pipe. Meaning I'd need a recirc flange, drill a hole in the piping on turbo outlet area. And drill hole on crossover to fit/weld maf sensor? Either that or put the MAF on the turbo inlet right?  Is an aftermarket recirc/blowoff valve recommended? Do currently have family in Japan so could probably bring something back with maybe a cheeky lil SuperAutobacs run?
    • Yep, so far most have said that it looks like corrosion on the wall from piston not moving. Which then has probably damaged the oil rings and caused those vertical marks. The longest the engine was still after the rebuild, was the winter of 2018 - 2019, plus the boat trip to Japan. When I shipped the car, it had normal gas in the tank but before that winter pause, it had E85 in tank.  In any case, even if either one of those was the cause, it happened close to 6 years ago and the car has been driven something like 30 000kms after the fact. Again, apart from the plugs and the dip stick, there is nothing in the way the car runs that would indicate what has been going on in the engine. I am going to consult a shop and ask their opinion, what would be the best approach. I do have some access to a garage I could use to diagnose further myself, but time is very restrictive. Might end up buying another engine that could be used while this one is being remedied. Without pulling the head, it will be impossible to find out if it needs another bore, but here's to hoping a hone would suffice.  Goddamnit, I would really have preferred this not happening.
