  • Replies 62.7k
  • chaos
    7164
  • Ska
    5791
  • BelGarion
    3645
  • Nexus9
    3590
whore wars eh, man they musta been full of pathetic idiots with nothing better to do then do what a nerd does best and sit in front of a computer posting useless things!
SO ALL BOW DOWN TO THE KINGS OF IDIOTS!
Guest
