  • Replies 62.7k
  • chaos
    7164
  • Ska
    5791
  • BelGarion
    3645
  • Nexus9
    3590
There was a moment last night, when she was sandwiched between the two Finnish dwarves and the Maori tribesmen, where I thought, "Wow, I could really spend the rest of my life with this woman".
how funny is the walk off scene in that movie?
There must be more to life than being really really good looking.
hey cyrus how I do lock down a PC so no-on can change jack shi7 on it without my permission? I know you've done it to all the PC's where you work.
Welcome to my area of expertice, I AM THE ULTAMITE NETWORK ADMIN NAZI!
Depends on wether your network makeup.
Is it domain or workgroup based?
Was OS are they running 98 or 2000/XP?
Oh ad:
Uhh Earth to Matilda, I was at a day spa. Day, D-A-I-Y-E. Okay?
Workgroup is slighty harder, but if they arent any 89 that is good poledit is a bitch!
Anyway what you need to do is setup a machine and set all the group policies for the local usergroup, this takes the longest because you can set access for nearly every single one of windozes fifty bagillion settings.
Once you have created this group policy then you'll have to go to each machine and apply it to the local machines user group and then add the user to that group.
Much easier if you were domain based, all done on the PDC and it flows through to all puters in seconds :P mUAhAH HAUUhAHu AHH H ahH H Ah HA hAH H AH h A hAH HAH AH HA h Ah AAaaa!!
If there is anything that this horrible tragedy can teach us, it's that a male model's life is a precious, precious commodity. Just because we have chiseled abs and stunning features, it doesn't mean that we too can't not die in a freak gasoline fight accident.
Well, I guess it started during my first year of the second grade, when I was eating lunch and caught my reflection in a spoon, and I thought to myself, 'Hey, Derek, you're ridiculously good looking! And I thought maybe I could do that for a career.
Do what for a career?
Be professionally good looking.
Guest
    • Nah it factory manual not sure about ratio but it looks like there’s been some work at the rear
    • so I need a new speedo cable
    • Throwing my spoon to the soup here a bit.  When I installed a 044 back in 2012, along with the direct power mod, the car became very difficult to start. To a point I burned one starter motor as I was late for work and tried to get the thing going. With some tuning and careful use of gas pedal when cranking it became bearable. Trying to make this short as possible, but the 044 died after 2-3 years, after which I went with an AEM 320lph pump, which also died after about 4 years to my dismay. After that I went with a Nismo pump, and while trying diagnose an emissions problem, I noticed for the first time that my fuel pressure was 5bar/72psi on idle, and that removing the vacuum line did nothing. After monitoring the situation, and removing the direct power feed and going back to FPCM in attempts to remedy it, I noticed there was fuel in the pressure regulator vac line. Kept the FPCM, installed AEM external regu and the car became sooo much better in every way, including starting. And I had driven it like it was for 11 years.. Anyway, I agree these are likely two different problems, and the FP problem you just haven't noticed before. I do not know much about haltecs, but what first came to mind was the CAS, which probably is not there any more. So how is the wiring from haltec to gauge cluster? How is the battery voltage and alternator?
    • Your car was auto before? You have different diff ratio (auto vs manual i think? or n/a and turbo?)
    • +1 for getting a screen off alibaba, CarPlay/Android Auto is vastly better than whatever navigation cars had 10 years ago. I got an Android screen for my 2015 BMW, huge difference. Fully compatible with factory stuff including iDrive controls.
