  • Replies 62.7k
  • chaos
    7164
  • Ska
    5791
  • BelGarion
    3645
  • Nexus9
    3590
- Lincoln and Kennedy were both killed on a Friday.- Both were killed in the presence of their wives.- Both were shot from behind and in the head.- Both assassins were killed before being brought to trial.
Like all insects, ants have six legs. Each leg has three joints. The legs of the ant are very strong so they can run very quickly. If a man could run as fast for his size as an ant can, he could run as fast as a racehorse. Ants can lift 20 times their own body weight. An ant brain has about 250 000 brain cells. A human brain has 10,000 million so a colony of 40,000 ants has collectively the same size brain as a human.
The average life expectancy of an ant is 45-60 days. Ants use their antenae not only for touch, but also for their sense of smell. The head of the ant has a pair of large, strong jaws. The jaws open and shut sideways like a pair of scissors. Adult ants cannot chew and swallow solid food. Instead they swallow the juice which they squeeze from pieces of food. They throw away the dry part that is left over. The ant has two eyes, each eye is made of many smaller eyes.
They are called compound eyes. The abdomen of the ant contains two stomachs. One stomach holds the food for itself and second stomach is for food to be shared with other ants. Like all insects, the outside of their body is covered with a hard armour this is called the exoskeleton. Ants have four distinct growing stages, the egg, larva, pupa and the adult. Biologists classify ants as a special group of wasps. (Hymenoptera Formicidae) There are over 10000 known species of ants. Each ant colony has at least one or more queens.
The job of the queen is to lay eggs which the worker ants look after. Worker ants are sterile, they look for food, look after the young, and defend the nest from unwanted visitors. Ants are clean and tidy insects. Some worker ants are given the job of taking the rubbish from the nest and putting it outside in a special rubbish dump! Each colony of ants has its own smell. In this way, intruders can be recognized immediately. Many ants such as the common Red species have a sting which they use to defend their nest.
The common Black Ants and Wood Ants have no sting, but they can squirt a spray of formic acid. Some birds put ants in their feathers because the ants squirt formic acid which gets rid of the parasites. The Slave-Maker Ant (Polyergus Rufescens) raids the nests of other ants and steals their pupae. When these new ants hatch,they work as slaves within the colony. The worker ants keep the eggs and larvae in different groups according to ages.
At night the worker ants move the eggs and larvae deep into the nest to protect them from the cold. During the daytime, the worker ants move the eggs and larvae of the colony to the top of the nest so that they can be warmer. If a worker ant has found a good source for food, it leaves a trail of scent so that the other ants in the colony can find the food. Army Ants are nomadic and they are always moving. They carry their larvae and their eggs with them in a long column.
The Army Ant (Ecitron Burchelli) of South America, can have as many as 700,000 members in its colony. The Leaf Cutter Ants are farmers. They cut out pieces of leaves which they take back to their nests. They chew them into a pulp and a special fungus grows it. Ants cannot digest leaves because they cannot digest cellulose. Many people think ants are a pest but I like them. To stop them coming into my kitchen I put some sugar outside. They they have so much to eat that they are not interested in coming into my kitchen.
Guest
    • Well, in 2007 he must have been charging about $1800 an hour. He only looked at the car for 5 minutes. And another 4 to write the report wrong, and another minute to correct it. Mind you, this was for a car that was: Stock engine, fmic (hole in drivers guard), all alloy intake and custom air box, 3 inch turbo back exhaust, lowered, and a set of 17" Advans (255/40/17 rear and 235/45/17 front). It was nothing crazy. The blue slipper wanted the "hole in the guard" engineered. But that was because he got the shits that I wouldn't "relocate the battery from the boot, back to the factory position in the engine bay"... In an R33 GTST...     Also for emissions, E85, and don't go wild on timing. It's amazing how the closer you get ignition timing towards max torque, the last couple of degrees really throw NOx counts right up. And for the huge increase in emissions, it's only a small increase in torque.
    • He'll be looking down and swearing about "the damn apprentice" for trying to convince Duncan to use percussive maintenance... 😛
    • I swear at my GKTech ones every time I have to take them apart and replace a spherical. But I wouldn't swap them for anything else. They absolutely slay every other option, at least in terms of how they actually work. You sure you don't want to live with bearings? I mean, they don't have "ball bearings". They are rod ends and sphericals throughout. Tough as nuts, even though I have found more than one way to wear them out.
    • From when I was looking at getting the 86 engineered for the turbo, the joint said to put in a few euro 5 or 6 cats, then tune the car on a nice clean E85 tune When I was looking at a turbo for the MX5, it was basically the same thing, a couple of cats and a nice clean tune Although, it will depend on the year of the Jeep IRT emmisions standards required, and what mods are done, especially if it has a newer engine installed that requires a higher Euro
    • Yeah - but it's not actually that easy. There are limits for HC, CO, NOx and particulates. Particulates shouldn't be a concern in any petrol engine unless trying to comply to the very latest Euro standard. But getting a tune right so that all the others stay within limits AT THE SAME TIME is not a trivial exercise. You couldn't possibly get it right by just guessing at the tuner's dyno, unless he had a 4 gas analyser up the pipe, which is not often the case these days. It used to be. Every decent shop that did "tune ups" (as opposed to tuning) would have a 4 gas analsyer. Perhaps there's still quite a few of them around these days. But most "tuners" are only watching O2 and power readings.
