erin u wouldnt know why was summoner stopped on highway on sat nite?  I was in one of the far right lane no way I can stop with the spastic traffic
He broke his diff aparently.
He went to sit beside that NIZ16 but when Shane down shifted, the diff broke. So he had to get it towed from Beenleigh to Annerley apparently.
  • Replies 62.7k
  • chaos
    7164
  • Ska
    5791
  • BelGarion
    3645
  • Nexus9
    3590
Err what tha!
tried to give you a call on sat or sunday ...can't remember which one, anyhoo I have my SAFC and was wondering since you are the master, and I have some cold beer maybe we could work something out LOL :rofl:
Hello peeps :wavey:
  Adrian I have the SAFC now, if you would still like to help us out when would be a good time for you ??
Probably not until after xmas mate...
Answ0red... in a roundabout sorta way... Prolly early Jan if that suits...
Guest
    • That's a given!  Bit hard to powdercoat it properly without removing them! 😁
    • No detail on compressor or turbine sizes, which doesn't help with housing size selection with that kit. However, from SR20DET mucking about and money torching perspective, a GTX2860R Gen 2 w/ 0.64 (46mm inducer) will do ~260kW on E85 about 1.5bar of boost. All in before 3000pm, which cause a gearbox to shatter. Now imagine the same turbo, on a modern motor with an extra 0.5L of displacement, and heaps of cam timing adjustability (not an on/off affair like the Nissan shit boxes). If this was my car (which I would never own or consider buying, ever!), I would go for a nice twin scroll setup, and a G30-660. Gates plumbed back, no silly shit. Lean on the cam timing, big displacement to create a flat-ish torque curve.
    • Do you plan on using 98 or e85?
    • This should be pretty easy. 200rwkW is just about the max power out of an RB25 stock turbo. So, 12ish psi on a 2.5L. That boost limited mainly by the prospect of seeing the turbine in the cat after the smoke show. A steel wheeled equivalent would likely happily do ~220rwkW at something like 17 psi, where it would probably be bumping into the usual limits of such a sized turbo. These things have like a .48 rear. You will not need the 0.86 rear. The 0.64 will be fine. In fact, if you were looking at various mid-200rwkW options for RBs, most of them would be in a 0.64 rear. So, I think you will definitely want to be no bigger than that for a same sized but probably even more efficient (at making power) modern engine.
