  • Replies 62.7k
  • chaos
    7164
  • Ska
    5791
  • BelGarion
    3645
  • Nexus9
    3590
EDIT
I have been informed that if I delete it it still stays in the database because mods can still see it, so a mod has to delete it so that it is purged from the database.
Bwahahhahhaa thats too funny :D
Guest
