Nissan Skyline GTR
The Skyline GTR is the 4 wheel drive, twin turbo super car that every one dreams of. The R34 car was launched on the 8th January 1999 and is basically a more compact, facelift model of the R33 which ran from 1993-1998. Other changes include the addition of 18" aluminium wheels as standard along with a 6 speed gear box and a multi function display unit (this has an LCD display giving 7 real time engine parameters). These cars are all around 300 bhp and go from 0-60 in 4.9 seconds.
  • Replies 62.7k
  • chaos
    7164
  • Ska
    5791
  • BelGarion
    3645
  • Nexus9
    3590
V-Spec:
This is the flagship of the GTR range. In addition to the standard GTR it has an improved engine performance due to a modified active LSD controlled in conjunction by a viscous coupling (Hence 'V-Spec'). It also has a stiffer suspension and an aerodynamic body kit to give better stability at high speeds. This model also boasts front and rear Venturi style diffusers (the rear one constructed from carbon fibre).
V-Spec II:
This model was introduced on 28th August 2000 and replaced the V-spec. The key difference is the carbon fibre bonnet instead of the aluminium one, with the addition of an NACA duct to aid engine cooling. Other differences include a black cloth interior and larger brake discs. This model is available in Bayside blue, white, white pearl, silver and black.
M-Spec:
The M-Spec model has been available since May 2001. It has leather trim, 'ripple-control' shocks and improved steering wheel. This is the luxury version and can be obtained in a special colour called 'Champagne Gold'. The other colours available are Black Pearl, Sparkling Silver and White Pearl. Due to the fact that the interior is hand sewn, Nissan only make 50 cars a month.
A group of unicorns is called a blessing.
Twelve or more cows are known as a "flink."
A group of frogs is called an army.
A group of rhinos is called a crash.
A group of kangaroos is called a mob.
A group of whales is called a pod.
A group of geese is called a gaggle.
A group of ravens is called a murder.
A group of officers is called a mess.
A group of larks is called an exaltation.
A group of owls is called a parliament.
The most poisonous animal in the world is not the daddy longlegs. In fact, from a little research, it seems that its not venomous at all. While it is true that their bite is too weak to penetrate human skin, the statement that their venom is deadly is false, an urban myth. From what I've read, even if they could penetrate human skin, they have no venom to deliver, although a spider called the cellar spider (which looks a lot like the North American daddy longlegs) is moderately venomous. Still, it does not compare to other venomous animals. The most venomous spider in the world is the funnel web spider of Australia. Phyllobates terriblis, or the Poison-Dart Frog of Columbia, is generally considered to be the most poisonous animal in the world.
Humans are born with 300 bones in their body, however when a person reaches adulthood they only have 206 bones. This occurs because many of them join together to make a single bone.
Guest
    • I don't really know general street pads too well, but there is no reason you can't get a low dust, long wearing, no squeal pad that works for those calipers at a reasonable price....they would just be a low end to medium price daily style pad.  If new pads don't have much bite or they loose it over time, it is probably just the pad glazing up which you can fix by giving them a good thrashing every now and then (or get the mechanic to deglaze them at next service) Track or semi track pads are where you have to put up with excessive dust (and potentially squealing as a side effect of that) in return for good bite and performance when very hot. Street pads have nothing like that sort of punishment, even long downhills with the brakes on are easier than a track session
    • lol yeah I'll check that, reminds me of the LDV thread!  I don't think that is the problem here, the starter doesn't even solenoid click. I did do a super quick test by removing the starter motor's power cable from the engine bay fuse box and the battery voltage was still 10v, so something super fishy is going on. BTW here is a R33 fuse box table I threw together from a few sources....use at own risk! R33 Fuse Box and Sources.xlsx
    • Johnny's approach, throw all the Nissan electronics into the trash. Best thing I've done to my shit box, go DBW.
    • Sounds like the JAX guys must have installed some really awful pads, are they BenShit/BenDicks pads by any chance?
    • Result of another R35GTR build. Similar specs as above except this is running our bigger size SS-2 profile option. Made similar power except this car runs on Pump 98 fuel. Build specs are: Nissan R35 GTR 2015 model stock engine and box. ETS street intercooler boost logi intercooler piping with tial bov, boost logi turbo inlet pipe ID 1050 injector DW 300C fuel pump Decatted oem down pipe and y pipe& HKS exaust 3inch intake pipe Upgraded actautors HyperGear SS-2 high flow option Final result is 639whp / 477wkws hubs, Ron 93 / P98 fuel at 20psi.
