  • Replies 62.7k
  • chaos
    7164
  • Ska
    5791
  • BelGarion
    3645
  • Nexus9
    3590
Evah seen a 4 door auto N/A R32 do skids? It's funneh says:
I <3 cyrus.
Cyrus - Ska - Drift0r - Beggar Extraordinaire! says:
Wassup biatch?
Playing with my oversized penis.
Love your work, pics or ban.
Yeh, here you go.
Oh your so big and bad.
I try my hardest to impress my biggest fan.
A weekend in the life of V8skylineMAN:
Here is a list what i have done to that in the last three days
motor in....
crank is different...fark...need manual
get clutch fit clutch
get pedal box and clutch master and slave cyl from r31 and 200b and modify to suit application
manual in...
all anciliaries bolted to motor
gearbox is 5inches shorter than the auto
fark....manual out.....run around like an idiot looking for a long 5speed(impossible to get one atm)
find out that crank is NOT different...
there is an adapter on the end of it....pulls off with two tyre levers
put auto back in....
realize that i cut all the lines that the auto uses when i took it out as i wasnt using it
run around like an idiot again to find the cooler lines...
find some at murrarie.
remove clutch master slave and pedal and go get auto lines.
fit auto lines to gearbox....remember that the motor doesnt have an oil pickup in it yet...
undo engine mounts
lift engine and remove sump....
go 1/2 way to toowoomba to get oil pickup
fit oil pickup
fit sump...lower engine....do up engine mounts...
fill with oil...fill auto with tranny fluid
fit tailshaft
try to start car,,,....nothing
find that wiring is all wrong on the auto...
fix wiring...try to start car....
car starts.!!!....exaust isnt done up.....FARK its loud!
turn car off.
fit exhaust
start car.....runs on 5 cyls only.....
begin diagnosis
find that no2 cyl is not firing.....
plenty of spark.....
check exhaust....no popping....not a valve
must be fuel suply to Injector....nope...plenty of pressure..
guess that injector must be the problem...remove injector(cvnt of a job)
replace injector
start car...WOOOOOO firing on all six!
fit radiator and hoses
fit fan
fill with coolant
let the car idle for 20 mins
not getting hot, go for a small drive....temp on 1/3....sweet
sit down and relax
Guest
    • Just checked in first post and you should be able to bring it home November this year, right? I'm amazed you made it through four years of this. As hard as it feels now the rest will go by in a breeze in hindsight, I'm sure.
    • Realized I haven't been back here in a while. Still here, still alive, still waiting for the car.  I went back again the only time last year from Oct-Nov for R's Meeting and drove it around some more, including a few laps on Fuji Speedway(in the wet, sadly). The car still feels good, but have a couple small things to address. I've been getting more parts but have slowed down still, and most of the bigger purchases are now out of the way. I find myself getting impatient more and more when it comes to getting started on this project; it's quite hard for me not being able to really dive in and start making this car my own because it's halfway across the world. At times it doesn't even really feel like I own one of these. Haven't really been motivated or had the desire to document the last trip on here or social media for, well, reasons... but here's some pics...it's also still alive and well as you can see: I've narrowed down to the last large part purchases(anything over $2k) before the engine build to be: 1) Ohlins Road & Tracks 2) ATS Twin Carbon clutch 3) Endless BBK with some custom options and 4) Kansai Service carbon driveshaft I don't think the budget exists for all of these this year, but I'll try for one or two items I think. Though, every time I look at my spreadsheet I sigh, shake my head, and get depressed just that little bit more.  'til later.
    • It's a stunning location!  I've been to NZ twice but haven't made it to the North Island yet.  Definitely on the cards but the South Island is hard to tear yourself away from too... Looking forward to see what you can wring out of it once you can get it to hold together!  Be awesome to get a low 11 or even sneaking into the high 10's pass out of it.  That's a bloody quick car that most people will never experience in their life.  Enjoy!
    • Nominally yes but I’m not really at that stage yet. Outsourcing to Japan is also a relatively good deal at the moment because their currency has devalued much more against the USD.  You would assume this but a lot has changed from the pandemic. Mechanics are in short supply and demand for fixing old cars has gone up from the cost of new cars. 250-300 USD/hr is not an unusual shop labor rate in California and you’re paying that regardless of whether the guy is competent or not. Coworkers have been quoted 3000 USD for a water pump and thermostat at a dealer on an N54. Oil changes went from ~75 USD to 150 on fairly normal cars like Civics. The cost of the oil and filter hasn’t even kept up with inflation.
    • The downside to that is that the cost of everything, particularly labour, is significantly higher here than it is over there in the Disunited States of Slavery. You can hire 3 tradesmen over there for just the Ranger Raptor allowance of a single 3rd year apprentice over here.
