i swear strutto we have to find someone that has a really worked auto 33.......there has to be people out there that have done it but ive had no success finding anyone on sau with heaps of mods on their auto. I dont think anyone has done any more work thats on sau then what i have
You coming to the dyno day in May?
Have to get your AFR's plotted and see where your at...
  • Replies 62.7k
  • chaos
    7164
  • Ska
    5791
  • BelGarion
    3645
  • Nexus9
    3590
AFR's arnt a huge concern to me as i know the e-manage works 100% and even has more mapping points then the safc.
I just want to know if the ignition harness will work and how far the auto box can go
You should be concerned... You got the $$ to pay for a rebuild?
are you going to get your safc tuned properly on the dyno strutto? or just leave what you put in? Have you been driving this whole time with ur settings or put it back to zero?
Still got my home tune in there...
Will be getting the AFR's plotted at the dyno day... I don't think they will be doing any tuning for ~$35...
Will modify the tune further based on the AFR's it makes...
Guest
    • No need to drill any holes. There's plenty of access to reach through and behind all of that steel to "push" from behind with a pulling action on the slide hammer. There's all sorts of attachments you can screw on the end of them.
    • Yea the photos aren't the best. When I was pulling the bumper and headlights out there was a bodyshop guy looking on for it, there is a slight bend behind where the passenger headlight is, but we're talking a few MM and there is a little bit of a bend for the reo. That said it's supposedly well within the "Drill a hole in it and pull it out with a slide hammer to be close enough" and be on our way. The other option is to buy a GTR reo for the GTR bumper bits but this is a $2000+ fix for something Mr Hammer can probably do 99% of the job for and everything will/can line up pretty closely-to-good-enough.
    • That's a write off for sure... Part out? 😛 I kid. It looks like the rad support has a minor minor bend in it too where the rep support sits near. Could just be the photos (and me not wearing my glasses right now). Worst case is you can buy a new radiator support, have it swapped over, and leave the car in paint jail for 12 to 18 months while you build the motor to handle twin turbos or a Harrop SC...
    • It seems the definition of "Gregging" something might need to be expanded?
    • This is why I suggested that there is really nothing that can safely be done in the engine bay at this budget level. Just the work to reassure yourself that the engine won't instantly crap itself the moment the boost gets turned up will wear out the piggy bank long before the first turbo gets installed. Spend $10k and still not have any extra performance? My tip is a version of our standard advice from 15 years ago about buying a GTR, which is not to buy one unless you can afford to buy two. The new version is not to modify a GTR unless you have all the funds required to do it all at once, properly, and enough to rebuild it after it blows up.
