  • Replies 62.7k
  • chaos
    7164
  • Ska
    5791
  • BelGarion
    3645
  • Nexus9
    3590
I am calling for a law to clothe all pet animals seen in public.. Just the otherday I saw a German Sheppard as naked as the day it was born! I could even see his "rude bits" - I am simply shocked and appauled.
We can call it the "animal nudity decency act 2005 - bylaw #53232-3AD, subsection 2, paragraph 5, sentence 6, word 3" !
I too have been mortified by the lack of morality displayed by these animals, so yes I whole heartedly second that motion
Actually Charly.. have you been sniffing that ajax again?.. there is only one thing that can explain that crooked nose Mr Candy Man!!
Oh I see you're suffering a case of amnesia. Are you forgetting the pictures I still have of you from our little thailand trip?
Actually you might, you did get pretty wasted that night.
Remember our little agreement, what happpens in thailand stays in thailand.
OK next by-law is in relation to the disgusting prevellance of phallus shaped vegetables...lets ban the sale and distribution of anything with dimensions that could be construed as non-square or non-round.
Anyone second that notion?
Yes I second that motion, on the proviso that phallus shaped vegetables can be imported from another constituancy direct to a rate payers home in a Brown paper bag if a rate payer so requires.
I as a "hot woman", understand that some of my less attractive female peers may not have the opportunity to form a "relationship" with men of your caliber and may have to resort to other means for gratification. And it would be negligent of me not to take that into account.
:) boy, this is getting too hot in here.. I think I am going to have to take off my clothes and pleasure myself with a pineapple..
Guest
    • Hows your intake piping? Are you still running stock? Having in the stock AFM position would mean, if the BOV was shut/venting out, it'd create the almost stalling kind of effect right // "the rich pulse behaviour" due to MAF thinking air is flowing ? But this would be better than having the bov in the stock position + MAF on/just before cross over piping right?
    • Essentially, yes. Although I wouldn't put the AFM on the crossover pipe. I'd want to put it into what amounts to the correct size tube, which is more easily done in the intercooler pipework. I bought a mount tube for card stile AFM that replaces the stock AFM - although being a cheap AliExpress knockoff, it had not flange and I had to make and weld my own. But it is the same length and diameter as the stock RB AFM, goes on my airbox, etc etc. I don't have a sick enough rig to warrant anything different, and the swap will take 5 minutes (when I finally get around to it and the injectors & the dyno tune).
    • So to summarise, the best thing to do is to move recirc to between turbo and IC, and maf on the crossover pipe. Meaning I'd need a recirc flange, drill a hole in the piping on turbo outlet area. And drill hole on crossover to fit/weld maf sensor? Either that or put the MAF on the turbo inlet right?  Is an aftermarket recirc/blowoff valve recommended? Do currently have family in Japan so could probably bring something back with maybe a cheeky lil SuperAutobacs run?
    • Yep, so far most have said that it looks like corrosion on the wall from piston not moving. Which then has probably damaged the oil rings and caused those vertical marks. The longest the engine was still after the rebuild, was the winter of 2018 - 2019, plus the boat trip to Japan. When I shipped the car, it had normal gas in the tank but before that winter pause, it had E85 in tank.  In any case, even if either one of those was the cause, it happened close to 6 years ago and the car has been driven something like 30 000kms after the fact. Again, apart from the plugs and the dip stick, there is nothing in the way the car runs that would indicate what has been going on in the engine. I am going to consult a shop and ask their opinion, what would be the best approach. I do have some access to a garage I could use to diagnose further myself, but time is very restrictive. Might end up buying another engine that could be used while this one is being remedied. Without pulling the head, it will be impossible to find out if it needs another bore, but here's to hoping a hone would suffice.  Goddamnit, I would really have preferred this not happening.
