Will anyone second that sandwich?
I will second it, IF it does not include any vegetables of the banned variety... i.e "including but not limited to"... carrots, cucumbers, zucchini, turnips, beets, parsnips, potatoes, radishes, corn, eggplants, rutabagas, sweet potato, kumara, yams, radicchio, okra, gourds etc etc
  • Replies 62.7k
  • chaos
    7164
  • Ska
    5791
  • BelGarion
    3645
  • Nexus9
    3590
I say we be even more obstructive and irrational. I think we should only ban those aforementioned phallic vegtables in their whole form. Therefore once you cut them in half they're perfectly legal.
The less sense it makes the funnier it will be for us. Think of the wave of angry letters from all the pensioners we'll get. :)
I will second that, IF and only if, the banned vegetables are prepared in a constituancy outside our own and imported in at great expense to the rate payer. My, and the female voters of this constituancy safety, is of the utmost importance to me and I cannot in good conscience allow a society of predatory males wandering the streets fresh with the image of phallic vegetables in their mind.
I, as an "extremely attractive woman" am constantly approached by lustful men and am fully aware that they do not need any further provocation by having these "lurid vegetables of the devil" waved in their faces day in day out.
Maybe we should actually form the interim sanctioned "Woman Against Phalli Association" this would help increase grievences against local greengrocers.
Protecting Greengrocers???
Please don't get me wrong, I mean I like "down a dirty, tie me up, watersport, nasty DVDA, sperm receptacle, bestial, unsafe group sex" as much as the next girl.
However, I cannot countenance the spending of hard earned council funding on protecting these filth peddlers. If they want to profit on the misery of women then they should use those profits to hire security to protect themselves.
I vote we stop Hansard recording at this point in time to discuss the alleged fund embezzling allegation.
Councillor Predator have you forgotten our additional *off the books* council funded retirement fund? I believe the councillor in question was transferring funds into said account.
Less said the better *taps nose*
I second that motion.
And may I reiterate for the minutes while speaking in verbatim about a proposed by-law to extend the opening hours for all local 'Mr Minute' outlets. Key replication & re-heeling has become an extremely neglected social aspect, and we must bring it up in our new agenda.
In furtherence to the Greengrocer issue
I have been offered a position on the Board of Directors in Company Chain of Greengrocers in another constituancy after my life in politics and a controlling share now. I therefore think it is in the ratepayers best interests to buy all our prepared vegetables of the banned variety from this chain of Greengrocers.
I suggest this only to save the rate payers a costly and exhaustive search for appropriate vendors from another constituancy.
In addendum if I actually lived in this constituancy, the rate payers would benefit from the arrangement with the return of rates paid by me into the council coffers.
Guest
    • Hows your intake piping? Are you still running stock? Having in the stock AFM position would mean, if the BOV was shut/venting out, it'd create the almost stalling kind of effect right // "the rich pulse behaviour" due to MAF thinking air is flowing ? But this would be better than having the bov in the stock position + MAF on/just before cross over piping right?
    • Essentially, yes. Although I wouldn't put the AFM on the crossover pipe. I'd want to put it into what amounts to the correct size tube, which is more easily done in the intercooler pipework. I bought a mount tube for card stile AFM that replaces the stock AFM - although being a cheap AliExpress knockoff, it had not flange and I had to make and weld my own. But it is the same length and diameter as the stock RB AFM, goes on my airbox, etc etc. I don't have a sick enough rig to warrant anything different, and the swap will take 5 minutes (when I finally get around to it and the injectors & the dyno tune).
    • So to summarise, the best thing to do is to move recirc to between turbo and IC, and maf on the crossover pipe. Meaning I'd need a recirc flange, drill a hole in the piping on turbo outlet area. And drill hole on crossover to fit/weld maf sensor? Either that or put the MAF on the turbo inlet right?  Is an aftermarket recirc/blowoff valve recommended? Do currently have family in Japan so could probably bring something back with maybe a cheeky lil SuperAutobacs run?
    • Yep, so far most have said that it looks like corrosion on the wall from piston not moving. Which then has probably damaged the oil rings and caused those vertical marks. The longest the engine was still after the rebuild, was the winter of 2018 - 2019, plus the boat trip to Japan. When I shipped the car, it had normal gas in the tank but before that winter pause, it had E85 in tank.  In any case, even if either one of those was the cause, it happened close to 6 years ago and the car has been driven something like 30 000kms after the fact. Again, apart from the plugs and the dip stick, there is nothing in the way the car runs that would indicate what has been going on in the engine. I am going to consult a shop and ask their opinion, what would be the best approach. I do have some access to a garage I could use to diagnose further myself, but time is very restrictive. Might end up buying another engine that could be used while this one is being remedied. Without pulling the head, it will be impossible to find out if it needs another bore, but here's to hoping a hone would suffice.  Goddamnit, I would really have preferred this not happening.
