well 11,800 people don't know how to spell it either :cheers:
.. I also want to see in F&F3.. that after their big meet and big battle.. some whinges over something petty, everybody bitch slaps them, and a fight breaks out..
(I also want to see them after beating each other in the final "big race".. there is no time for celebrations.. they all rush home to their computer and sit their typing profusely about it)
  • Replies 62.7k
  • chaos
    7164
  • Ska
    5791
  • BelGarion
    3645
  • Nexus9
    3590
yeah, i can see it now.. I think this must be done.. F&F SAU QLD pisstake style!
Dominick: Hey O'Conner.. Woa, that one was close.. I'm going to call this a night and head back to my computer to type it all up before I go to bed
Brian: Yeah mate, good idea, respeckt brotha, respeckt.. I'll post up all those photos I took whilst driving my car and screwing the girl too... "
Dominick: Don't forget those witty comments after each one too, and maybe a random picture of a truck as well
Brian: Sure thing brotha... sure thing
F&F3,
Walker: What car should we take to the drag meet?
Dom: Maybe we should get some parts for our hondah civic like spoon engines n motec system exhausts do you think then we can beat a 9sec drag car???
Walker: Dom once again your missing the point.....unless we get these neons under the car...tonight, theres no point racing coz we dont stand a chance at attracting 100's of car ****s.
Dom: Walker dont you know why i always tear off my shirt?? We dont need 40 neons to win...I already covered the car in oversized and incorrectly spelt chrome graphics.
Walker: Your always one step ahead of me....maybe thats why I dont see you blowing the welds on your intake.
Dom: What can I say....I live my life a 1/4 mile at a time :cheers:
Guest
    • Hows your intake piping? Are you still running stock? Having in the stock AFM position would mean, if the BOV was shut/venting out, it'd create the almost stalling kind of effect right // "the rich pulse behaviour" due to MAF thinking air is flowing ? But this would be better than having the bov in the stock position + MAF on/just before cross over piping right?
    • Essentially, yes. Although I wouldn't put the AFM on the crossover pipe. I'd want to put it into what amounts to the correct size tube, which is more easily done in the intercooler pipework. I bought a mount tube for card stile AFM that replaces the stock AFM - although being a cheap AliExpress knockoff, it had not flange and I had to make and weld my own. But it is the same length and diameter as the stock RB AFM, goes on my airbox, etc etc. I don't have a sick enough rig to warrant anything different, and the swap will take 5 minutes (when I finally get around to it and the injectors & the dyno tune).
    • So to summarise, the best thing to do is to move recirc to between turbo and IC, and maf on the crossover pipe. Meaning I'd need a recirc flange, drill a hole in the piping on turbo outlet area. And drill hole on crossover to fit/weld maf sensor? Either that or put the MAF on the turbo inlet right?  Is an aftermarket recirc/blowoff valve recommended? Do currently have family in Japan so could probably bring something back with maybe a cheeky lil SuperAutobacs run?
    • Yep, so far most have said that it looks like corrosion on the wall from piston not moving. Which then has probably damaged the oil rings and caused those vertical marks. The longest the engine was still after the rebuild, was the winter of 2018 - 2019, plus the boat trip to Japan. When I shipped the car, it had normal gas in the tank but before that winter pause, it had E85 in tank.  In any case, even if either one of those was the cause, it happened close to 6 years ago and the car has been driven something like 30 000kms after the fact. Again, apart from the plugs and the dip stick, there is nothing in the way the car runs that would indicate what has been going on in the engine. I am going to consult a shop and ask their opinion, what would be the best approach. I do have some access to a garage I could use to diagnose further myself, but time is very restrictive. Might end up buying another engine that could be used while this one is being remedied. Without pulling the head, it will be impossible to find out if it needs another bore, but here's to hoping a hone would suffice.  Goddamnit, I would really have preferred this not happening.
