  • Replies 62.7k
  • chaos
    7164
  • Ska
    5791
  • BelGarion
    3645
  • Nexus9
    3590
I put it to the hourable member of P51,
that it may be in the best interests of the rate payers for her to drive around in the "white, air conditioned, turbo-charged council vehicle" at councils expense until such time as the committe for the reallocation of summer heat has found a suitable arangement for the redistribution of excess temperature in the electorate..
Ahh councillor Hottie... If only you knew...
I put forth the motion for councellor members to purchase a Air Conditioning unit for Council Member P51.
seconded.. and also for aircondition to be repaired in Member for KnowNothing's cars also..
group buy on aircon fixups?
the honourable charly would like to know exactly how many times the member for psi has broken her airconditioner since the purchase of the white government vehicle?
Member for psi, don't be cheap. Buy us some icy poles. It's crazy hot in here.
Since you're asking I'll have a lemonade one.
I disagree...even though great deals of cash were spent, they were mearly petty upgrades, therfore the cash must still be there.
Unless the missing money has been allocated to the honourable Smooth for this equipment I found in his office-
My council provided vehicle still does not have working coils... I'm going to form a committee to discuss whether we should think about petitioning to have their repair sent out for tender.
Where the hell are the icy poles?! I demand a prompt resolution to this most urgent of issues.
Councillor Batwing, this is the second compressor thing I have bought for the government vehicle to replace the original broken one that we won't go into the story of.
Because of budget cuts, I was informed that I should purchase a second hand compressor from a "wreckers" which only lasted 3 weeks until it broke in the same manner as the original compressor.
The airconditioning in my government funded car is still functional, it just isn't functional when sitting still at sets of lights.
Attention Councillor Revhead
It has come to my attention that you may have become a victim of identity theft as per here....
http://www.skylinesaustralia.com/forums/me...php?userid=1965
As we all know the dangers inherrent in the use of the internet and the need to take care when giving out personal information, it does not however give someone the right to steal someones identity in the event such care has not been taken.
I hereby propose that the council bring the full weight of our displeasure against this identiy thief.
What say you councillors?
Guest
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
