  • Replies 62.7k
  • chaos
    7164
  • Ska
    5791
  • BelGarion
    3645
  • Nexus9
    3590
of course.. but unless you know people in japan pretty much a no go.. even if you do its going to work out a **** load.. have to pull out a perfectly nice RB26DETT , find a SR20det that works, put it back in, ship car to australia... get it complied, then ship engine separately and get it all fitted after compliance and reg'ed.
By the time you add it up, may as well just convert it once its in australia.
well just the cost involved as well.. each "engine in-engine out" would cost you at least $1000, and there is 4 involved in what i was saying might be possible :P
meh.. government sux.. burn them all.. install me as president and bow down before me!! :bahaha:
ok.. evil meglomaniac plans off
lol.. so if u eat their crap after work you get a bigger discount? lol ..thats funny :P
just got an online quote for the r31.. $158.21 3rd party fire and theft for a year! Now if we could only get that on all the rest of our skylines :P
Guest
    • What can't be done with a little bit of decking board or similar timber bolted to a hub flange via 2 wheel nuts is not worth talking about.
    • I noticed something. On the tps sensor and the sensor behind the adjustment screw is adjusted towards the far left. Are these screws supposed to be centered? (this sensor was in the same position before the tune as well)  Also attached a photo of where my car usually idles at when warm (sometimes a tiny bit above that). I think I might have screwed up the calculation and it might have better than I thought lol at 750rpm still not 650rpm though.
    • So for both general interest of engine health, and to rule out any coolant/oil issues, I organised an oil analysis done on the 125,000klm oil Results below, all good, just a bit of fuel dilution which I'm not too worried about
    • This is actually a really good way of measuring what wheels fit. If only there was a similar measurement between hub face and suspension :p That said, it's probably pretty simple to actually measure it all with the wheel off the car for the rear. The front is a bit more complex but..
    • Being the top Google search result for R34 wheel-related inquiries, lemme throw down my experience. I calculated that 100mm from hub face to wheel face is about the perfect fitment for my ENR34 sedan.  I've been running 18x8.5s, ET35, with a 1" spacer. So, 8.5in to mm = 216mm. 216/2 = 108mm. 108-35 = 73mm. 73+ 25 (1" to mm) = 98mm.  If you wanna get close to this on dif widths, here are the offsets you'll want: 9" - ET around 15mm 9.5" - ET around 20mm 10" - you're crazy, but ET around 30mm All these should fit perfectly on a non-widebody, non-GTR Skyline. Note that it's probably the absolute max, and you're probably better off running a couple degrees of camber in this config, but it looks great, super flush.
