  • Replies 62.7k
  • chaos
    7164
  • Ska
    5791
  • BelGarion
    3645
  • Nexus9
    3590
hmm.. true.. thursday can't possibly be a rest day can it? :P
Maybe it can just be a meet then? I'm happy to find some nice routes and eventually plan one, just takes some time.
BAH who needs planning, I didnt plan my mountain run, I just pulled a UBD out and went that looks good!
really? I thought u might have known the route. I prefer to drive it first.. I have an idea that I went on when I first came to QLD. Down Goldcoast way. Its a bit hairy scary though.
Anyhow I've done the honours so at least people can argue about where to go.. hehe
but I have to remember which way it was :P lol
Nope never did it, so we did make a couple mistakes, like zooming past the first stop point at breakneck speed, blame strutto though I was the passenger and said, yupp we just went past where we were supposed to stop, oh well :P
*looking around for GenesisR32 Antagonist aka yamathu33
no more unquoted quotes from you eh? you lucky.. my usb ports died on my last night when JL came by my place to hook up his digi cam... been using alot of 'tab' just to type this msg :P
Guest
    • But it's much better to use a freedom unit that has four different possible meanings...
    • I would try messing with friction modifier to see if it smooths it out.  Just keep adding more until it stops chattering or grabbing quite so much. If you haven't changed the gear oil in a long time you may as well start there too in case that has anything to do with it. You might want to also verify the initial torque is set to the lowest setting too. Requires popping out one of the CV axles first but that's not too bad. Once you're sure the preload is set to the lowest you can try adding an ounce at a time of friction modifier until it feels right to you.
    • It is possibly 55 degrees for the Nismo version. I had a look through the manual and the stocker has a breakaway torque of 2.5 to 3.5kgm. Supposedly the Nismo LSD goes down to 5kgm when worn in but it is pretty grabby even with very little throttle. Worse when cold. So I guess you have three things. 1. Shims. 2 Friction plates 3. Cams Would think shims would be the easiest but Ive no clue how many tenths of a mm shim thickness change equals how many kgm torque. Also not sure if the Nismo friction plates are similar/different to stock or if they are the most of the source of the diff being angry. Think I can write off the Nismo rebuild kit for the standard diff as not being what I want.
    • Yeah, it was a bit of confusion with me, I rang and asked if they had a boot for a soft top, and then the paint shop when they rang and were asked if it had a hard top on it, which it does, just not a PRHT....LOL Meh, whilst frustrating for all concerned it isn't a war stopper and should be a thing of the past in a week or two In other N/A related news, car is booked in at the end of the month for the cams, springs, retainers, harmonic balancer and retune  I might even pull the lazy arse card and get them to do a full service on it whilst it is there
