  • Replies 62.7k
  • chaos
    7164
  • Ska
    5791
  • BelGarion
    3645
  • Nexus9
    3590
s there anywhere to go once you get to the top of mt cootha? or just back down
see i don't know these things :) Only been there once during the day.. to be honest I'm happy just to sit around for a bit and chat, and maybe go for a small run. Not up for anything maniacal at the moment
yeah but im a commo driver. if i can get a lift in a SILVER R33 4 DOOR THEN I WONT BRING IT OUT. LOL
just after a lift as well , as I am on crutchers for another week at least and don't get my line back for about another 2 to 3 weeks
did he actually see you yesterday when you drove past yesterday Adrian?
Certainly looked like he did... Apparently he's a little cranky at me? No idea why... Was quite pissed at Ska for even contemplating inviting me on there little weekend adventures...
I wasn't going to go... But I think I am obliged now...
How about Skas' proposal which included Stamford?????
that sounded quite entertaining
That sounds quite enjoyable Gordo...
Oh, you were spotted in the Who is Who thread too.... :wavey:
Guest
    • But it's much better to use a freedom unit that has four different possible meanings...
    • I would try messing with friction modifier to see if it smooths it out.  Just keep adding more until it stops chattering or grabbing quite so much. If you haven't changed the gear oil in a long time you may as well start there too in case that has anything to do with it. You might want to also verify the initial torque is set to the lowest setting too. Requires popping out one of the CV axles first but that's not too bad. Once you're sure the preload is set to the lowest you can try adding an ounce at a time of friction modifier until it feels right to you.
    • It is possibly 55 degrees for the Nismo version. I had a look through the manual and the stocker has a breakaway torque of 2.5 to 3.5kgm. Supposedly the Nismo LSD goes down to 5kgm when worn in but it is pretty grabby even with very little throttle. Worse when cold. So I guess you have three things. 1. Shims. 2 Friction plates 3. Cams Would think shims would be the easiest but Ive no clue how many tenths of a mm shim thickness change equals how many kgm torque. Also not sure if the Nismo friction plates are similar/different to stock or if they are the most of the source of the diff being angry. Think I can write off the Nismo rebuild kit for the standard diff as not being what I want.
    • Yeah, it was a bit of confusion with me, I rang and asked if they had a boot for a soft top, and then the paint shop when they rang and were asked if it had a hard top on it, which it does, just not a PRHT....LOL Meh, whilst frustrating for all concerned it isn't a war stopper and should be a thing of the past in a week or two In other N/A related news, car is booked in at the end of the month for the cams, springs, retainers, harmonic balancer and retune  I might even pull the lazy arse card and get them to do a full service on it whilst it is there
