  • Replies 62.7k
  • chaos
    7164
  • Ska
    5791
  • BelGarion
    3645
  • Nexus9
    3590
adrian: i can provide basic directions from NGC to that shopping centre point .. i think it should be good. Never been that way myself which is a bit scary.. but it all came to me on the map the loop :)
I think we will be right Gordo... I've been out that way before to help out some fellow sedan owners...
Not gunna nerd it up with Pred here and get into an argument over it but I'll add the following...
IP address - Internet Protocol.. basically every computer has one of these addresses..
There are public and private addresses... Every device on the internet or in a TCP/IP network has one...
TCP - Transmission Control Protocol - form of sending stuff over the internet
Tick... All TCP/IP networks use TCP to send information between devices...
Packet - small block of information sent via TCP
Or other network protocols...
Browser - you're looking at one
Yep... the bit that displays the HTML...
HTML - hypertext markup language. Using basic text language plus special tags to designate the text and make it appear different (the markup).
Not gunna argue with master...
JPEG - Graphic, damn forget what it is.. i learned it in uni :)
Joint Photographic Experts Group... A form of picture compression to shrink the size of a picture to make it less demanding on bandwidth...
MP3 - Multiplexed sound (i think).. basically encoding sound so the bits that are drowned out by high volumes straight after are thrown away as they are inaudible anyhow.
MPEG1 Layer 3... Preds description is correct... A form of audio compression to shrink the size of a sound to make it less demanding on bandwidth...
Bandwidth.. bah.. my brain just broke :D
The amount of traffic a network can carry for a given amount of time...
Oh, and google will be most helpful if you need more detail...
Guest
    • Hows your intake piping? Are you still running stock? Having in the stock AFM position would mean, if the BOV was shut/venting out, it'd create the almost stalling kind of effect right // "the rich pulse behaviour" due to MAF thinking air is flowing ? But this would be better than having the bov in the stock position + MAF on/just before cross over piping right?
    • Essentially, yes. Although I wouldn't put the AFM on the crossover pipe. I'd want to put it into what amounts to the correct size tube, which is more easily done in the intercooler pipework. I bought a mount tube for card stile AFM that replaces the stock AFM - although being a cheap AliExpress knockoff, it had not flange and I had to make and weld my own. But it is the same length and diameter as the stock RB AFM, goes on my airbox, etc etc. I don't have a sick enough rig to warrant anything different, and the swap will take 5 minutes (when I finally get around to it and the injectors & the dyno tune).
    • So to summarise, the best thing to do is to move recirc to between turbo and IC, and maf on the crossover pipe. Meaning I'd need a recirc flange, drill a hole in the piping on turbo outlet area. And drill hole on crossover to fit/weld maf sensor? Either that or put the MAF on the turbo inlet right?  Is an aftermarket recirc/blowoff valve recommended? Do currently have family in Japan so could probably bring something back with maybe a cheeky lil SuperAutobacs run?
    • Yep, so far most have said that it looks like corrosion on the wall from piston not moving. Which then has probably damaged the oil rings and caused those vertical marks. The longest the engine was still after the rebuild, was the winter of 2018 - 2019, plus the boat trip to Japan. When I shipped the car, it had normal gas in the tank but before that winter pause, it had E85 in tank.  In any case, even if either one of those was the cause, it happened close to 6 years ago and the car has been driven something like 30 000kms after the fact. Again, apart from the plugs and the dip stick, there is nothing in the way the car runs that would indicate what has been going on in the engine. I am going to consult a shop and ask their opinion, what would be the best approach. I do have some access to a garage I could use to diagnose further myself, but time is very restrictive. Might end up buying another engine that could be used while this one is being remedied. Without pulling the head, it will be impossible to find out if it needs another bore, but here's to hoping a hone would suffice.  Goddamnit, I would really have preferred this not happening.
