so it is definatly mine? i can start telling people :rant: mmm cant wait to see works face when i quit
Well the job is yours on the two factors:
1. You still want it once you have see what you have to do.
2. The production manager is happy with your work effort.
If you can fill out those two criteria then you have a job here as long as you want basically!
  • Replies 62.7k
  • chaos
    7164
  • Ska
    5791
  • BelGarion
    3645
  • Nexus9
    3590
you should storm out in the middle of a shift infront of a full counter and scream " You mean I have to wash my hands EVERYTIME I go to the toilet , not just the first time "
hmmm i'll work hard dont you worry :rant:
I dont doubt it, but as I said once we start hiring you'll be first on the list of people who get called for "interviews" which are just like 5 mins of this is the work, this is the pay, when can you start. And they rest is up to you bud!
cheapest rims for the 33 are the stockies/200sx rims. I had about 4 sets of them in melb :rant:
Generally go for about $400 with some tyres.. but don't seem to come up much in brisbane here. No idea where the old stockies go when people upgrade! probably back of some dodgy wheel workshop
What's the new job going to be ???/
Wooden truss manufacturing, he'll probably start off counting ancillaries and then either move onto the presses or saws, depending on openings and how hard he works.
Hey do you have your forklift ticket? If not if you get one then you could get one of the fork driving jobs, man that is sweet, drive a forklift round all day loading and unloading trucks!
Guest
    • They are what I will be installing. 640s for me.
    • Hmm... From my experience you get about 0.25° camber change per mm of RUCA length change. So, to correct from -2.5 up to less than -1° (or, more than -1° if you look at the world as a mathematician does) then you'd be making 6-8mm of length change on the RUCA. From a stock length of 308mm, that's 2-2.5% difference in RUCA length. My RUCAs are currently very close to stock length - certainly only 2-3mm different from stock. I had to adjust my tension arms by 6mm to minimise the bump steer. That's 6mm out of 210, which is 2.8%. That's a 2.8% change on those, compared to a <1% change on the RUCAs. So the stock geometry already has worse bump steer than is possible - you can improve it even if you don't change the RUCA length. If you lengthen the RUCAs at all, then you will definitely be adding bump steer. Again, with my car, I recently had an unpleasant amount of bump steer, stemming from a number of things that happened one after another without me having an opportunity to correct for them. I only had to change the tension arm lengths by 1mm to minimise the resulting bump steer. (Granted, I also had to dial out a lot of extra toe-in in the rear, and excessive rear toe-in will make bump steer behaviour worse). Relatively tiny little adjustments having been made - the car is now completely different. Was horrifying how much it wanted to steer from the rear on any significant single wheel bump/dip. And it was even bad on expansion joints on long sweepers on freeway entry/exits, which are notionally hitting both rear wheels at the same time. My point is, the crappy Nissan multilink is quite sensitive to these things (unlike the very nice Toyota suspension!). And I think 99.75% of Skyline owners are blissfully ignorant of what they are driving around on. Sadly, it is a non-trivial exercise to set up to measure and correct bump steer. I am happy to show my rig, which involves nasty chunks of wood bolted to the hub, mirrors, lasers, graph paper targets and other horrors. Just in case anyone wants to see how it is done. I'll just have to set it up to take the photos.
    • What do you have in that bad boy ? Ill go with the 725cc since I'll be going with Nistune ( would definitely like more engine protection but Haltech is too far out of reach at the moment... plus, Ill probably have a pretty safe tune as its a daily, not gonna be chasing peak power 24/7 ahahah ). Are Xspurt a safe choice?  Pete's great. He didnt mention anything about traction arm length so I reckon it may be good. When I get some new wheels/tire later down the road I'll ask him about it and get his opinion on em. I heard from Gary that you've got the bilsteins too, are you running the sway bars too? and what other suspension goodies do you have installed or would recommend?
    • In true Gregging style...
