  • Replies 62.7k
  • chaos
    7164
  • Ska
    5791
  • BelGarion
    3645
  • Nexus9
    3590
Hey Nex you know what you need to setup in your store, about 50 computers networked with a heap of games and rent them out at like $10/hr to play, I know there is something like this in brissie, but nothing around here on the coast.
I really miss my gaming puter, sold it for the deposit on my skyline, so it went for a worthy cause :(
Yeah I needed a deposit for the loan and once I had a test drive of it I new what I had to do, instead of thowing money into the bottomless pit I called my gaming computer, I'd change it to a bigger, deeper hole :rofl:
damn that is two bottomless holes I contribute to, computer and skyline
(one could debate that the other half is another bottomless pit regards money, but she reads here every now and again, so I won't)
I really miss my gaming puter, sold it for the deposit on my skyline, so it went for a worthy cause :D
theres like 10 of them in brisbane i go to the bunker on queen street but its only $4 an hour so you would be hard pressed at getting people at $10 an hour :rofl:
Guest
    • Re read everything that has been written about this in this thread.. Let us know if you're still confused.
    • This would be a new pump with new gears. I'm just unclear on whether it's a good idea to run more oil pump flow if you don't actually need said flow. Oil level is set a minute or so after shutting off a warm engine so wouldn't the high RPM oil level in the sump end up lower all things equal? Plan is OEM clearances, main concern in my mind is whether the OEM pump can keep up with the flow requirements of any additional oil coolers.
    • Don't do what I did, use a 300000km old housing with billet gears. The old pump probably was clearanced with saw dust, Edward Lee's special engine treatment sauce and a good odo wind back. I had oil pressure issues, then replaces pump with new housing, new billet gears and 2x track day later binned a motor due to other oil related issues due to a previous engine builder. Long story short, buy a M2 or 3 or 4 N55/S55/S58 and enjoy life.
    • Yeah. "New pump" does not have to mean "massive pump".
    • Well, can you still get an OEM pump, and by the time you're buying a Nismo/N1 etc, just buy another aftermarket pump. It's better to have the pump able to flow more if its needed, than for your pressure to drop off. At any point in time, you're replacing the oil pump in a rebuild. Aftermarket pumps are likely going to be a better economical choice, and they don't have any negatives, even if they can flow more.   Also, when you're saying "replace the pump gears" are you meaning leave a 25+ year old housing in the engine with unknown wear, and just put new gears in? As that sounds silly to me, especially if you do have that minute amount of wear, that means your new pump gears now have a little bit more clearance beside them, which means, whelp, you may not get to build a lot of oil pressure or make a lot of flow.
