I'm a tightass so use the Mobil1 SemiS stuff. Seems fine, seeing as i'm pretty hardcore on the changes on every 5k -- bit expensive $55 or so each time for the full synthetic.
SemiS is usually only $32 or so.. It does say "designed for turbo charged engines". Probably not as good for the engine as fully synthetic but my engine is still running strongly.
  • Replies 62.7k
  • chaos
    7164
  • Ska
    5791
  • BelGarion
    3645
  • Nexus9
    3590
Guys .. i need some help..
when need to start a 'find flux a friend' campeign or something .. because im so over being a loner..
im thinking of moving back to sydney because its just not happening up here..
so please feel free to donate a human to this fund preferable female aged between 18 - 25 with out any ****in mental issues ;)
please?
ill be your best friend!!
Nah i just think it is the way the light fell, here is a bigger picture... http://www.skylinesaustralia.com/photopost...&sort=1&cat=500
The Front bar now that is a different story, that is badly in need of respraying at the moment, I want to do it but I also have another veilside front bar to go on when I get the FMIC, so I don't want to get it sprayed if I am getting it replaced soon, but I am hating they way it is at the moment too.
Hmmm decisions, decisions ;)
I don't know yet,
I was thinking of keeping it "just in case" but I don't know if I want a front bar hanging around the back of the house indefinitely.
I guess I will decide when the time comes.
Why? are you interested in it?
I feel for you mindflux,
when I first left highschool I went and lived in Europe for a year by myself, man there were some lonely times there at the beginning.... but you stick with it and it comes good eventually.
Just have to have faith in yourself that you are a good person and that you have something to offer I guess.
doesn't make it easy though ;)
A female of any age without ****in mental issues is a huge ask nowadays
I blame it on reality TV ;)
now mindflux: don't go killing anybody now will you?
I should go down to DMD and pick up my sideskirts, nice day for it!
Mindflux, you sound like patrick batemen. Go and read Some Brett Easton Ellis and if you understand it on any level be very worried. and you really have to stop caring so much. Also if you're all jaded on relationships this might help clarify how women's minds work. Sorry if it's a repeat.
www.laddertheory.com
and remember if you see a guy who is clearly a dud with a really really hot girlfriend don't envy him. Pity him.
Guest
    • Thanks for taking the time to post that ! If anything changes or happens please do update us.
    • Somehow Vertimass/Oak Ridge National Labs has figured out a catalyst that can convert ethanol into C9-C10 hydrocarbons in basically a single step without ending up with a bunch of ethylene or similar waste products: https://patents.google.com/patent/WO2023224867A1/en I still don't think anything like this will keep us from needing to transition to EVs regardless along with all kinds of other electrification, but things like this will go a long way towards alleviating the problem of how to electrify things like planes. Renewable diesel is seemingly an easier problem as well, Chevron is already running refineries for the stuff and the primary feedstock is tallow and other waste fats from agriculture.
    • Ok so I have sorted everything with my uniclutch and  i can offer up a bit of feedback and some things that might help others.    I found problems with factory damper line. Weird shit and had trouble with peddle adjustment    I used this https://au.gktech.com/products/r33-gts-t-skyline-braided-clutch-line?_pos=2&_sid=22b01b9b9&_ss=r Also when adjusting peddle leave a bit of play. You can get into a over stroke condition easy.. Make sure you can push the slave forward after adjusting to confirm fluid can return to master then you will need to pump it up heaps…..not sure why but that’s how it is.    last thing the splined adapter is machined perfectly. If your input shaft is old like mine was I would put a bit of valve grinding paste on it and stroke it like a 15 year old. Just to give it a tad more clearance and to better match it to the spline.    reason is on a near flat shift I have had situation where the peddle returns a millisecond after you lift from the clutch. No slip or anything but I reckon this is due to tolerance on the spline being way tighter than stock clutch and binding for a sec. I think this will go away but also my spline was old. Box is old so I guess I should have checked better. It’s a super neat fit.    it feels light as and holds awesome without any noise
    • My Fuga Hybrid is JDM, 2014 model but very similar to the V37 from the looks of things..same platform just physically larger and very comfortab;e
    • Was that Australia Delivered Duncan? Does it have siren etc?   I used to have remote start on an old 32 two decades ago, it was a cool feature. I used to wake up early in winter for work. Start it and by the time i was out the door a few minutes later the engine was warmed up and the heaters had the car toasty. It was great.    I don’t mine the ambience lighting.  I drive a western star and it has footwell lights and ambient lighting and it’s great! From the pics of seen of them installed in a skyline I think it’s a nice touch
