  • Replies 62.7k
  • chaos
    7164
  • Ska
    5791
  • BelGarion
    3645
  • Nexus9
    3590
I cant believe I am slowly catching chaos, he he he once he starts working he will be too tired to whore :D
plus, if he is shacking up with Ska....they will have to come to some kind of arrangement with the connection...
Hey Ska?? does your dsl modem have an inbuilt switch?
Nope, plus I have a linux box doing the firewalling so I'll just limit his connection speed to zero :D MAMAUaHAHa hahaaH AHha ha ha ha HAAAaaa!!
Plus I do not own a hub/switch dsl modem to linux box then to windows box via cross over so if he wants in he'll have to learn to share, when I am not home, or buy a hub :D Even then he'll wont be able to run a cable out to the garage, it is seperate to the unit :)
don't be mean, how about taking him back to the days of the Commodore 64 mmmmm 6.4K Baud rate modems..... nice
you are a hard man....is there a phone line out there?
dunno what he is bringing, I think he uses the family puter so it'll have to wait when I am not home, cause my puter is in my bedroom, next to bed, (yeah I know what you are thinking, evil discusting men, and yes you are right) so nil access when I am on it or sleeping, which is most of the time I am home :D
Hey im goign to install a HKS turbo timer..
should i buy a wiring harness?
im getting it put in the same time as im getting my alarm so it works in wiht my alarm
so wil i need to get a harness or not?
no
Guest
    • I know right. It baffled me. There's no way when the engine is off, key is in ignition, (coils are dissconnected aswell), also my sound system was dissconnected (I don't run any audio capacitors), battery reads 12.2v and with the 10amp fuse blown I was measuring 24 to 30v. The reading would move a bit from 30v to 24v which was weird. I took a pic of the multi meter reading 🤣: (This is a brand new single channel digital oscilloscope that also has a multi meter mode).   Before when the fuse was blown, I had one lead on the 12v supply (green/white wires) of that brown relay and the other lead on the negative battery terminal. When I turned the key on ignition (engine off), it would read 30v. Then when I removed that relay from it's plug and tried putting ignition on again, it would read 12v, but I think it's because it can't turn on the ecu now that I removed it. I asked Chatgpt and this is what it had to say:   Not sure if those theories would be possible but, any auto sparkies here? welcome to confirm. 🤷‍♂️  No idea, but if it happens again, atleast I know what type of issue it is, unlike last few months where I didn't know what was causing all my issues and I was just taking stabs in the dark to figure out what type of problem it was. If it does happen again I'm going to investigate futher and trace back the source even more and inspect more circuits. I drove it to work this morning and the car drove and boosted fine. Yeah I was thinking the same, so I've imported my back up saved map (which is the map that I saved when it got done tuning) back onto my haltech with the base fuel pressure set to 43.5psi.
    • Yeh nice, if your in melbourne could you recommend any exhaust shops in the east that do a good job?
    • Sorry yes, this is what im after Also, that jpjdm site appears to be offline
    • @Duncan Random side note, did the cops give you the driver/owners details of the taxi and then did Shannons give you a refund of the excess once you supplied those details?
    • Yeah to be clear I'm not naive, I'm sure all insurance companies are a bunch of arseholes who pay people bonusses based on the value of genuine claims they avoid....I just don't want to go back to one that has personally f**ked me multiple times in the past
