  • Replies 62.7k
  • chaos
    7164
  • Ska
    5791
  • BelGarion
    3645
  • Nexus9
    3590
adrian, how do i get my PM's to popup? Cause i dont notice them for ages otherwise
Sam,
If you go into your UserCP up in the top left...
Then click options on the menu on the left...
Go down about half way...
There is a check box labeled "Show New Private Message Notification Pop-up"
Tick this and choose save down the bottom...
It won't pop up until you open or refresh a new SAU page...
HTH!
Guest
    • Kaizo Industries put a VIN plate over where the Nissan plate would go. It was part of how they broke the law and attracted feds going after them.
