not 100% on exh side AR... its the 8cm2 i am running at the moment. And i dunno where the post is, but i think it was by Steve, he showed a comparison table that related cm2 to AR
Reason for selling: Building an RB30DET and this ---->
is sitting next to me :P
EDIT:
3" i think exhaust
600x270x55 FMIC
EMS Dual Sport ECU
stock!!! injectors
550hp fuel pump
Stock fuel pressure
Stock engine internals
2.25" intercooler piping
  • Replies 62.7k
  • chaos
    7164
  • Ska
    5791
  • BelGarion
    3645
  • Nexus9
    3590
well assuming its on an RB20det right now and will bolt straight on...
you will need to block the water feed (comes from inlet side around the back of the head via metal tubing) and water return in the block.
Once that is done a tune would be very wise!
Then once that is done you will notice a big grin on your face :P R32's are MUCH lighter than my car ;) And with the power i got my car gets up and boogies all over the road on boost... well used to, brand new 255's have calmed that a fair bit.
But cuz i bought my turbo from a guy who already had it on an R32 RB20, all i did was unbolt my stocker, plug up the water lines, bolt new turbo on, then drove around with the old tune for 2-3 weeks before i got it tuned.
i did get the dump pipe modified to suit my car etc. Which you will need a custom dump pipe by the sounds of it
Pred, the rb20 turbo is classed as a non good turbo.
lol :P maybe, but then again they were designed to be cheap to make and give 165kw or whatever the stock R32 power output is ;) So they do that. Just like the stockie RB25 turbo isn't great either..
wish i had the funds for an 2530 myself. Probably what i would go for -- not after big dyno figures.
Skyrine-Dave : watchout.. might chew up that phone...mmm.. RB30 + big ass turbos :)
Predator: It can chew that fone.. well try! its lasted many drunken nites in town... read: Dropped all over the place :P good old 3210 reliability :)
I did want a 2530, but being a tight ass uni student didnt really allow for it. I previously had a hi-flowed R32 turbo and that sucked so much ass its not funny. Sure the car was powerful... compared to my old V8 Fairlane 500 (god bless it ;))... but it sucked none the less.
As i see it. The 2530 sounds like a very nice turbo for an Rb20, but not having been in a car with one on it... i cannot comment. Tho i've seen some Rb25 owners not happy with 2530's due to their extra capacity.
yeah.. heard that - HKS 2530 will only give 230rwkw or so on an RB25DET. Apparently though its meant to spin up quicker than the stocker and give you a bootfull of midrange which sounds nice. Keeps the engine nice and safe anyhow.
anyhow, i'm off..later all.
Dave - so running it on the stock engine and stock cooler would be fine? at 7 psi?
whats the lag like .. doesnt get on boost to 5 grand or something?
is turbo lag a good or a bad thing?
oh man! stock cooler... i wouldnt bother. With my hi-flow i had so many over heating issues with my stock cooler!!!
FMIC at the same time or before... or ASAP once you install it. makes a huge difference... i went from 47deg inlet temps to 25deg inlet temps!
Turbo lag... hmm u can drive around casual just makin spool noise but not coming on boost, just goin all casual and quiet around the streets... but mash ya foot to the floor... 4000rpm and all hell breaks loose...
i like the lag so i dont have to drive on boost all the time. as the car is daily driven.
Personal preference really. The only time i kick myself is when i'm in the wrong gear and have 2000rpm before decent boost kicks in when having a "roll on"... problem solvered by dropping it back a gear... or 2 and away you go.
OK here's the deal the $5 do not have plastic covers and have really been used and show it, all the pages are in and not looking at falling out, but you can tell they've been heavily used. The $10 are from here in the office and are perfect other than the plastic is faded.
These are also for sale to anyone inside the company so dont know how much longer they will be there for, but we did have about 30 to start with so guess whoever wanted one has one by now, but yeah dont know how much longer I'll be able to get them for.
$5
1.
2.
$10
1. Nexus9
2.
Alright last chance anyone want a cheap UBD, going, going..............
Guest
    • Hey lads, reviving an old thread.  As an update, since the last time replied to this thread, ive done mostly suspension. Havent touched the motor except for maintenance. Though upon changing spark plugs, found out i had splitfires pre-installed! Updates: - Got me some stock airbox top cover and snorkel to fit onto the original intake. Should be free of defects - Bought a set of R34 GT-T brakes (not installed yet, going to rebuild + respray in champion blue + white 'Nissan' text) - Bought the last set of bilsteins from @Sydneykid and had them installed. Has been making some sounds on the rear but hopefully should be sorted out after this New Year break. - Regreased front caster rod bushings (poly bushes..) - Rear upper camber arms - Whiteline sway bars (BNF27Z 22mm + BNR11XXZ 24mm).  The rear sway bars are a bit short (ive read 50mm else where) but was still able to get them in.  Anyhows, I reckon suspension is sorted now. Maybe replace bushes (do have a set of front upper control arms from SK not installed yet) but should be okay for now. From now, I'm wanting to start working on the motor, drivetrain etc etc. Still debating on the order to go on and what to buy etc but: - ECU ( Haltech or Link ( Link states that it dont support A/T or AWD functions... Can anyone attest to this? ) - Highflow turbo ( ATR43ss2 ) - Intercooler ( Not decided yet, but cant find many good afoordable ones. Toshi says to opt for crossflow Japanese. Bit difficult this one, unless I get a returnflow Blitz from JJ? ) - Injectors ( Any recommendations ? I do have a nismo FPR ( Thanks SK ) ) - Seats - Tune by either Toshi or DVS To be fair, I did consider just keeping the stock turbo and nistuning it. Sat in a mates stock N, that had something like 200kw, and I reckon that felt more than enough. Maybe I should just go this route ahhaha. Too many choices.... Planning a trip down south, so wanting to just clean things up and make sure it gets to and from in one piece. Anything else specifically I should do before ? Cheers lads
    • Must be for the car’s lucky charm 🤷🏽‍♂️ She runs fine, but it just seems to take about 1L less. Maybe I’ll have the oil sump dropped at some point to check if there is anything
    • Hmmm interesting. Mine is the exact same and clearly the right one.  The mystery of the engine oil being full after 3.5-4L continues
