  • Replies 62.7k
  • chaos
    7164
  • Ska
    5791
  • BelGarion
    3645
  • Nexus9
    3590
Charly - Cool I'll be printing out a heap too, double sided though to save paper :starwars: Also depending on time and if I could be bothered, I am going to highlight the roads on the maps.
Too bad you're missing this thursday Zoixy, it's gonna be a blast :stupid: But better off keeping your car in one piece for you know who :devil:
OMG again! help!!
my car isnt boostin right :starwars::stupid::devil::(
i dunno what but i have been playin wiht the blow off vale and in first and second it wont boost.
it normally comes onto boost at 3 grand (going by the stock boost guage)
but i noticed it wont go above 0 till about 5 grand in 2nd .. and i dont think it boost at all in 1st
to come onto boost do i have to plant my foot? ..
because i was testing it and i only applied half the throttle pressure.. and instead of comin on at 3 grand it started to come on at 5 .. and even then it only went up a quarter of the way
How old are you?
Fairly young to get an stomach ulcer I would of thought...  Must be a fair amount of stress in your life... :starwars:
Did they take your swollen appendix out?
I had shingles when I had just turned 18 in my first job. The copper that was my boss (Inspector) gave me soo much grief I got shingles.. Then when I rang up tell them I had shingles, she said "yeah right erin, come in and show me. I dont believe you" .. So here I am in severe pain in the heat wave we had in September 2001 having to go show my boss that I had shingles...
Lovely hey :S
Lovely hey :S
Yeah we all love coppers don't we... :starwars:
the great news is my car is also leaking power steering fluid too, it just gets better and better
Most 33's leak fluid from around the power steering resevoir...
In fact, I think most older cars I've looked at leak from around the power steering resevoir...
Hey Cyrus..
What did Gavin end up saying about your car? Is it good or bad?
Dunno, Amanda said they might get around to looking at it today, but you know how busy they are, I felt so much like ringing up and asking, but knew that they are probably flatout, so I'll try to be painent and wait for them to call, its just PURE AGAONY the wait though, I hate waiting for bad news, rather just get it over and done with, but do understand how busy Gav is, so i will have to wait my turn, AHHA hAHHAgAghAHHAhAGGAHHA AgHAAHGGAag GAghGHAgagh
Sorry had to get that outta my system, going crazy thinking about it :starwars:
Guest
    • So we have most the interior back in, and for the first time with one OEM speaker hooked up. The 31 is running, driving and now tunes!!! Hahaha yet another step for the sub that sat 10m under for two weeks!!! unbelievable really 👌 lots of love work and not giving up on her. Seen so many youngsters part way less, and in way better condition. I’m stubborn, thinking another problem is just a hurdle to overcome, One at a time. IMG_9277.mov
    • That is correct. I'm using a modified ABS ring and a ZF speed sensor on my rear diff for speed input. I'm running a Haltech ecu.
    • Been busy with the newborn. We originally thought we were going to go for a third, but we're good with two lol. He's starting to actually sleep now so I've had some energy to work on the car. It's been parked away in the garage since late November due to winter.  I went ahead and redid all my head oil drains. I originally had my front and rear head drain going into the same pipe but have since split them up. I also added an Ethanol content sensor to get ready to run E85 this summer. Tossed it on my return line. Sensor sits nicely under my intake manifold.    I also have a lot of parts that came in for my rear end. I'll be swapping over to a 3.3 final drive and doing the GK teck anti squat mod. While the rear subframe is off, I'll also change every bushing. We're planning on buying another house soon with the condition that I get at a minimum a 2 door garage, so I'll wait to have more room for this. Now onto the strange things that recently happened... After changing the lower rad hose (It had been sitting in my cabinet for well over a year and was the last hose I had to replace), I let the car idle in the garage to bleed my coolant. After running for a few minutes, it started missing. Got much worst within a minute or two and then stalled and would not restart. My crank sensor decided to crap itself. No damage, no explanation, just died. I went ahead and replaced it with another ZF sensor but the heavier duty stainless model with a shield. Tossed that in and started right up. Has anyone else seen this? I hate when things fail without cause. Luckily this was a blessing in disguise... This lead me to recheck my timing. It seems I may have had a beer or two the last time I had set my TDC angle as I was off exactly 5 degrees... I miscounted a line haha. I was running 5 degrees less then commanded. It's a little embarrassing but helps explain why my dyno operator seemed to think I should be making more then 478rwkws.
    • Sharing results from recent Liberty Walk R35 GTR, since they are still considered as somesort of a V36 Skyline. We do them turbos too. This are high flowed SS-1 models with ball bearing conversion done.  Car have managed to pull 485awkws @ 20Psi so far pushing limitations of factory built engine. The build list for R35 GTR enthusiasts as follow : HyperGear high flowed stock turbos in SS1 (G25-660 specs) Custom titanium intake pipes. Vspec performance titanium front pipes. Vspec performance 4" titanium exhaust. Upgrade fuel pumps. 1200cc injectors. Ignition coilpacks Hks intake plenum. Hks intercooler piping. Greddy intercooler. Greddy bovs. Top-secret coolant reservoir. Emtron ecu. Straight E85. Built gear box.
    • Nah no bearings, just slip fit.  Would be a reasonably challenging but not impossible job to modify it to run bearings but I'm hoping that's not necessary as I may have well built one myself if I end up spending hours modifying it!
