yup, leases can be traps. You're not really "owning" anything. Of course with employer deductions and things it can be worthwhile, but otherwise.
mj: yeah, went very well.. here is pretty much the sum of it:
http://www.skylinesaustralia.com/forums/sh...ead.php?t=38169
It may be a while before i can take it out and really test it to see whether it really made a difference, but i suspect it will.
  • Replies 62.7k
  • chaos
    7164
  • Ska
    5791
  • BelGarion
    3645
  • Nexus9
    3590
hey smooth, did you get gav to look at your car? whats the go with it?
Nope, he was too busy...
Havnt really driven it so I will take it in next week hopefully...
I had a mate come over he thinks its a combination of black thin oil... very slipping clutch... and sparkplugs a bit fouled...
Also confirmed th sound was coming from the idle pulley which isnt a prob...
Will get it compression tested at gav's to see if there is any probs with the engine etc
:wavey:
the plastic pipe was installed by the previous owner. Looks a bit scrappy, but held to the FMIC piping via a zip tie and cloth tape -- classy i know.
As we were saying the other day, bunnings could be a good place to get it. They have like plastic garden irrigation piping, which is about the right size, and can be bent to size. I've got mine running through the old return pipe for the stock IC (which I no longer have)
Guest
    • What can't be done with a little bit of decking board or similar timber bolted to a hub flange via 2 wheel nuts is not worth talking about.
    • I noticed something. On the tps sensor and the sensor behind the adjustment screw is adjusted towards the far left. Are these screws supposed to be centered? (this sensor was in the same position before the tune as well)  Also attached a photo of where my car usually idles at when warm (sometimes a tiny bit above that). I think I might have screwed up the calculation and it might have better than I thought lol at 750rpm still not 650rpm though.
    • So for both general interest of engine health, and to rule out any coolant/oil issues, I organised an oil analysis done on the 125,000klm oil Results below, all good, just a bit of fuel dilution which I'm not too worried about
    • This is actually a really good way of measuring what wheels fit. If only there was a similar measurement between hub face and suspension :p That said, it's probably pretty simple to actually measure it all with the wheel off the car for the rear. The front is a bit more complex but..
    • Being the top Google search result for R34 wheel-related inquiries, lemme throw down my experience. I calculated that 100mm from hub face to wheel face is about the perfect fitment for my ENR34 sedan.  I've been running 18x8.5s, ET35, with a 1" spacer. So, 8.5in to mm = 216mm. 216/2 = 108mm. 108-35 = 73mm. 73+ 25 (1" to mm) = 98mm.  If you wanna get close to this on dif widths, here are the offsets you'll want: 9" - ET around 15mm 9.5" - ET around 20mm 10" - you're crazy, but ET around 30mm All these should fit perfectly on a non-widebody, non-GTR Skyline. Note that it's probably the absolute max, and you're probably better off running a couple degrees of camber in this config, but it looks great, super flush.
